SU HIF7 carb leaking
Old Dec 1, 2013 | 09:36 AM
bergpa's Avatar
Default SU HIF7 carb leaking
Hi everyone,
just recently bought a '77 XJ-C 4.2 from it's first owner, but unfortunately both carbs are leaking at the bottom seal of the float chamber.
Can I remove the float chamber cover from underneath the car without removing the carbs from the car and simply change the seals or are parts going to drop out when I unscrew the float chamber lid?
Thanks in advance for your comments and kind help.
Truly appreciated
Patrick
Old Dec 1, 2013 | 05:02 PM
Fraser Mitchell's Avatar
Are these Zenith Strombergs or SUs ?
Old Dec 31, 2013 | 04:44 AM
Daimler's Avatar
Hi Patrick,
The HIF7's float bowls are only a base plate at the bottom which you have mentioned. Given that the internals of the carburetors aren't damaged nothing should fall out. Hold a rag underneath incase. I can't remember off hand how the HIF7's floats are mounted but I have a feeling via a screw from the outside?? Good luck.
Regards,
Alex
Old Dec 31, 2013 | 09:56 AM
Next time, I'll read the thread title !!
You can get SU spares, (even complete carburettors), from a UK company called Burlen Fuel Systems.
Old Dec 31, 2013 | 11:10 AM
simonphillips21's Avatar
hi patrick you lucky soul i love the xjc. hif carbs do have a very shallow float bowl that will want cleaning out but you may find needle is sticky hence leaking unless seal has degraded. do check fuel filter as may be muck in tanks if low mileage car.
Old Jan 22, 2014 | 05:01 AM
BrettPritt's Avatar
Old Jan 23, 2014 | 02:11 PM
bergpa's Avatar
Thanks guys for your helpful comments
It was nothing more than a degraded seal
Everything bone dry again ant the jag purrs like a kitty again
Old Jan 23, 2014 | 03:37 PM
Good to hear it's all fixed. Where did you get your carburettor parts ?
Old Jan 26, 2014 | 06:17 AM
bergpa's Avatar
Got the parts from SNG Barratt
Old Jan 26, 2014 | 06:38 AM
Great to hear you have it resolved bergpa
Sounds like SNG Barratt was a saviour, really cool to have them here with us now as a vendor too.
ahunt4
Sep 25, 2015 03:43 AM
ebrand
E type ( XK-E )
Sep 23, 2015 11:34 AM
rusty37
Sep 18, 2015 10:03 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
