SU HIF7 carb leaking
Hi everyone,
just recently bought a '77 XJ-C 4.2 from it's first owner, but unfortunately both carbs are leaking at the bottom seal of the float chamber.
Can I remove the float chamber cover from underneath the car without removing the carbs from the car and simply change the seals or are parts going to drop out when I unscrew the float chamber lid?
Thanks in advance for your comments and kind help.
Truly appreciated
Patrick
Truly appreciated
Patrick
Hi Patrick,
The HIF7's float bowls are only a base plate at the bottom which you have mentioned. Given that the internals of the carburetors aren't damaged nothing should fall out. Hold a rag underneath incase. I can't remember off hand how the HIF7's floats are mounted but I have a feeling via a screw from the outside?? Good luck.
Regards,
Alex
Regards,
Alex
Next time, I'll read the thread title !!
You can get SU spares, (even complete carburettors), from a UK company called Burlen Fuel Systems.
hi patrick you lucky soul i love the xjc. hif carbs do have a very shallow float bowl that will want cleaning out but you may find needle is sticky hence leaking unless seal has degraded. do check fuel filter as may be muck in tanks if low mileage car.
It was nothing more than a degraded seal
Everything bone dry again ant the jag purrs like a kitty again
Good to hear it's all fixed. Where did you get your carburettor parts ?
rusty37
Sep 18, 2015 10:03 AM
OkieTim
Sep 8, 2015 04:48 PM
