temporary water pump fix?
Old Feb 22, 2014 | 12:53 PM
jjd's Avatar
jjd
Default temporary water pump fix?
Im still trying to source a water pump for the show season but in Ireland all i get is shoulder shrugs or rubbing hands in glee from parts suppliers. If you dont have a 2ltr diesel x type then forget about it here.
Anyways i have to use my series 3 next week for a 50 mile round trip and the pump is leaking from the inspection hole on the pulley indicating seal failure. I ran a bottle of Holts Seal It through the cooling system and the leak is now near non existent, its now losing maybe a egg cup in an hour running at idle in the garage. I presume the pump is still doing its job and this temporary fix will see me safely on my way until a pump is sourced that doesnt cost more than the car is worth? Or will pump fail spectacularly on me very soon?
As i say, the car is running well temperature is steady, low coolant warning light remains off and all appears ok? Opinions much appreciated folks.
Old Feb 23, 2014 | 10:23 AM
JagCad's Avatar
Tis a luck of the draw issue. As yo cooling, just be prepared with extra coolant to keep the level up. it may get messy, but the engine will be safe as long as it has coolant.
Even if the pump seal leaks badly, it will likely continue to circulate coolant and that is it's function.
The problem is that as the pump shaft not only has an impeller to suppiort, it also has the mass of the fan. And, that is a huge load.
So, wear will increase exponentialy. Not good.
if your 50 mile voyage does not include a lot of stop and go and is at road speeds, ie 50 mph or retter, I'd consider removing the fan and it's clutch.
Whatever happens, don't push it hot, it will not be good.
Carl.
Old Feb 23, 2014 | 10:46 AM
Jose's Avatar
why not order a new water pump from SNG Barrat UK or US stores ???
Old Feb 23, 2014 | 10:55 AM
Doug's Avatar
As Carl say, it's a luck issue. Some people have it, some don't
What you call an 'inspection hole' is often called a 'weep hole'. If the amount of coolant coming from the hole is indeed nothing more than a 'weep' than I wouldn't give the matter much more than a shrug of the shoulders. It might be years before it develops into an actual dripping leak.
If you're already at the 'dripping stage', well.... good luck can be pushed too far !
Old Feb 23, 2014 | 11:34 AM
jjd's Avatar
jjd
Ok ill chance it so guys, thanks for the advice. As far as ordering from sng, or anywhere else for that matter, its about 450 Euro delivered. Considering the car is worth a grand at the most here im not giving that for a pump. Im sure one will turn up at some stage.
Old Feb 23, 2014 | 05:07 PM
icsamerica's Avatar
Water pump at my local autozone is 198.00
USPS quoted shipping of $56.00 for international flat rate or 111.00 for any standard box.
I wont know if the pump will fit in a flat rate box until I try it. The flat rate box is 11" x 8-1/2" x 5-1/2"
I'm willing to ship it to you as I have a post office walking distance and I drive past about 3 AutoZone's every day. PM me if you're interested in this.
Old Feb 24, 2014 | 11:00 AM
SNG Barratt USA's Avatar
Former Sponsor
Hello
The pumps from our UK store are in the 90 (vat if applicable) pound region.. They should be able to ship it to you economically also. Their phone number is 01746 765432
Old Feb 24, 2014 | 01:13 PM
rgp's Avatar
rgp
I got this email 2 day It may be worth trying these, scparts
If there is anything you are interested in or need to order please contact me for a 1 off special price, I will also beat any of our competitors prices on a like for like part so always come to me! Please also take a look out our new website below for our brand new products and prices.
Have a good day.
Kind Regards
Chris Laker
+44 1293 847210
engineering@scparts.co.uk
enquiries@scparts.co.uk
www.scparts.co.uk
Old Feb 26, 2014 | 06:43 AM
jjd's Avatar
jjd
Cheers for the help folks, the quick fix has held up so far anyhow. On the subject of more reasonably priced pumps i find that i get quoted for complete pumps built up from each component part priced separately which pushes the price up,ie: pump housing, impeller, seals etc etc then postage here is always quoted at extortionate rates. I try pricing direct and through motor factors and by the time the initial reasonable price reaches the bottom line its not worth it. As i say the cars themselves are so cheap here it makes more sense to eventually hold out for a secondhand part.
Old Feb 26, 2014 | 08:50 AM
Jose's Avatar
if you want a second-hand pump, there is one guy who dismantles XJ: David at Everyday XJ.
Everyday XJ
contact him for a delivered price.
Old Feb 26, 2014 | 10:00 AM
Wilfred88's Avatar
I am not sure if a series 1 waterpump is the same, but if it is you can get mine at a decent price. shipping is around 20 gbp. (16 euro)
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
Sprayall
May 30, 2021 08:13 AM
Saturbo
Sep 8, 2015 07:35 PM
Sprayall
Sep 3, 2015 07:49 PM
