Warm Idle Adjustment Screw Location?
Old Jul 28, 2019 | 06:16 PM
James O's Avatar
Default Warm Idle Adjustment Screw Location?
MAF sensor on 84 XK engine (Federal) -- is this the warm idle adjustment screw?
Forgive me if this has been answered, but I've searched and couldn't find it.
My 84 XJ6 (Federal, California) runs fine while cold, but idles low (~700RPM) when warm, and gets rough and sometimes stalls. Shifting into neutral helps but not enough.
As a first step I thought about trying to adjust the warm idle. I've seen this discussed at length in various places, but I'm having a hart time visualizing the location of the proper adjustment screw. I've attached a photo of the MAF sensor on my car (best angle I could get). I added an arrow. Is this the proper screw to use to adjust it?
I don't want to adjust the wrong screw on the MAF if I can help it. I have enough trouble with this sort of thing without digging a deeper hole for myself.
Thanks in advance,
-James
Old Jul 28, 2019 | 06:36 PM
Doug's Avatar
That's the mixture adjustment, not warm idle speed.
Old Jul 28, 2019 | 06:37 PM
Doug's Avatar
Idle Speed Adjustment
Old Jul 28, 2019 | 06:54 PM
James O's Avatar
^^ thank you. I've read that and I've looked, but for the live of me I just cannot find it. Does anyone have a photo of it?
Old Jul 28, 2019 | 07:09 PM
Doug's Avatar
Go to post #5 of this thread
https://www.jaguarforums.com/forum/x...-screw-141875/
Old Jul 28, 2019 | 07:21 PM
David84XJ6's Avatar
Idle trim (RPM) adjust is about 1" inboard and 3" down (from your yellow arrow point) on the intake manifold.. covered by vacuum lines et. al., but it is there. in an aluminum fitting. see red arrow
Rgds
David
On intake manifold below red arrow
Old Jul 28, 2019 | 07:24 PM
James O's Avatar
Thank you both, Doug and David. I'll see if I can locate it.
Old Jul 29, 2019 | 01:11 AM
David84XJ6's Avatar
James,
Once you find it, you will be wondering how to get a tool into that location to do the adjusting??? Dozens of solutions by clever Jag owners, this is the one that I copied, can't remember who posted it, but it works for me, and can be found in my trunk emergency kit.
Rgds
David
7/32 Allen wrench with a little propane heat and a vice to bend into position.
Ubad2
Feb 18, 2018 11:01 AM
jeffn
Jul 3, 2016 01:51 AM
Willafizz
Jul 19, 2015 04:54 PM
jaguars4r
Aug 8, 2012 10:40 PM
hlgeorge
May 5, 2010 08:29 PM
