Water Pump Leak
Old Sep 30, 2017 | 03:35 PM
Hettle's Avatar
Default Water Pump Leak
Hello,
I have a 1991 XJ6 that is leaking coolant from somewhere around the water pump, i can't quite locate the leak. The closest i can get is that it is dripping off the pulley that is connected to the water pump. It only leaks when running, hot or cold. If anyone has any resources or an idea of what could be leaking that would be awesome!
Mathew
Old Sep 30, 2017 | 05:40 PM
Coolant dripping from the pulley is the Classic symptom water pump failure whether running or not.
The seal has gone allowing coolant to escape around the shaft and drip off the pulley.
Cure: New water pump.
Old Sep 30, 2017 | 06:21 PM
o1xjr's Avatar
Welcome to the forums, when you get a moment please post an intro in the new member area.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Your water pump will have a weep hole on the underside just behind the pulley. They start dripping out of here when the seal has failed. As Elinor said, replace the water pump.
You can see it dripping with a small mirror and torch.
Old Sep 30, 2017 | 11:10 PM
Hettle's Avatar
Attachment 203532Attachment 203533
Thank you for the response, I've made an appointment to get the water pump replaced. I also have a hose coming right off the water pump that is swollen a little bit, should i replace this myself before i bring it to the mechanic or just wait and get them to do it? I won't be driving the car except to the mechanic. Thanks!
Old Sep 30, 2017 | 11:29 PM
Daf11e's Avatar
If your having the water pump replaced by a mechanic you may as well let them do it as they'll be in there anyway and it will be warranted.
Old Oct 1, 2017 | 05:25 AM
Originally Posted by Hettle
I have a 1991 XJ6 that is leaking coolant from somewhere around the water pump .....
Mathew,
Your 1991 XJ6 will be an XJ40 and not an XJ6 Series III.
In this instance the symptoms and solution will be similar but please post future technical questions in the relevant forum:
https://www.jaguarforums.com/forum/xj40-xj81-25/
Old Oct 1, 2017 | 11:07 AM
Hettle's Avatar
Originally Posted by GGG
Mathew,
How do you know its a XJ40? on my insurance papers and VIN number check it said XJ6?
Old Oct 1, 2017 | 11:18 AM
Doug's Avatar
"XJ6" is a marketing designation, used for decades, on significantly different cars.
To segregate the cars for discussion the engineering designation or platform designation...such as "XJ40".... is often used. The XJ6 name was also used on the "X300" platform....and an and even more modern one..."X350" perhaps? Not sure.
Anyway, a 1991 XJ6 can only be an "XJ40"
This all began in 1986-87 when the older Series III XJ6 was being built concurrently with the newer and very different "XJ6". Using the engineering designation ..."XJ40"....was an easy way to differentiate between the two
Old Oct 1, 2017 | 11:55 AM
Hettle's Avatar
That makes much more sense now and will help a lot with searching for diagnostics etc.
Thanks!
Old Oct 11, 2017 | 11:52 AM
new mexico's Avatar
Hello,
Mathew
Get a replacement water pump from rockauto to fit your engine #.
Walter
Old Oct 11, 2017 | 11:59 AM
JagCad's Avatar
In every "modern: critter, a leaking, weeping or even squeaking WP is fixed only by a new or rebuilt one
Way, way, back when, a leaker could be fixed with "water pump pliers" to tighten the gland nut. The tool survives, a plumber's favorite.
Carl
Old Oct 11, 2017 | 08:52 PM
Carl
So That's how they got that name!!
I've wondered about that all my life!
Thank you, Carl!
Old Aug 14, 2018 | 07:33 PM
Adrian L's Avatar
Guess I can't just put a little permatex in the weep port hole, eh? I thought it was the gasket, initially.
This is a very easy part to swap. I'll get a re-manufactured one from Terry's and in an hour or two be back in business.
Old May 25, 2020 | 02:05 AM
philipmsuh's Avatar
Talking
Hi everyone,
I've finally taken the courage to DIY -- replacing the thermostat, radiator, and water pump. Kinda nerve-wracking, but you know what? This pandemic made me do it!
I was wondering if my Jaguarista seniors can help me out: can someone pls explain the steps on replacing the water pump? I think I can do the thermostat and the radiator somehow. But the water pump?
instructions would be very nice. And yes, pictures are cool too.
thanks, all!
Old May 25, 2020 | 02:14 AM
Sparkplug's Avatar
If you can find the Wheeler Dealers TV episode where they worked on a Jaguar XJ6 coupe it might help. They dealt with a failing bearing in the water pump.
it is not on YouTube but maybe somewhere else?
Old May 25, 2020 | 03:17 AM
philipmsuh's Avatar
https://www.dailymotion.com/video/x50rlcp.
Thank you! This was EXACTLY what i was looking for. Will let you know how it goes!
pdfisherman
Aug 21, 2016 11:20 PM
o1xjr
Aug 7, 2014 09:28 AM
sidescrollin
Apr 21, 2012 07:47 PM
afonda
Nov 19, 2010 05:18 AM
LedZepplin
Jun 8, 2010 06:54 PM
