what thread for wheel nuts
Old Feb 19, 2014 | 03:50 AM
Anfield Dreaming's Avatar
Default what thread for wheel nuts
Can anyone tell me what thread A XJ series II uses for wheel nuts? Thanks
Old Feb 19, 2014 | 04:38 AM
Memory again, 1/2" National Fine.
Also called UNF in some areas.
Old Feb 19, 2014 | 07:01 AM
Doug's Avatar
Otherwise known as ½-20
Old Feb 19, 2014 | 07:59 AM
Cheers first the info much appreciated
Old Feb 20, 2014 | 09:08 AM
One final question on this open or closed end nut?
Old Feb 20, 2014 | 06:08 PM
AristoCat's Avatar
.50" x 20°
Old Feb 20, 2014 | 06:22 PM
Doug's Avatar
Jaguar typically used a closed nut with alloy wheels and open nut with steel wheels.
But, some of the 'closed' nuts were actually open nut with a bright stainless steel cap crimped on....and usually with a pre-installed washer.
What wheels are you using?
Old Feb 20, 2014 | 06:24 PM
Doug's Avatar
Originally Posted by AristoCat
.50" x 20°
20º ?
The thread size is ½-20 with the '20' being 20 threads per inch
Old Feb 20, 2014 | 09:12 PM
AristoCat's Avatar
I was always told, it was a 20° pitch.
I shall investigate.
Old Feb 21, 2014 | 04:24 AM
Steel chrome smoothies as a replacement for 15" lattice I was told I couldn't use the same nuts off the alloys does this sounds tight?
Old Feb 21, 2014 | 04:25 AM
*Right
Old Feb 21, 2014 | 09:06 AM
AristoCat's Avatar
Default you're 100% correct.
Originally Posted by Doug
20º ?
My aplogies for spreading missinformation.
Old Feb 22, 2014 | 06:25 PM
Doug's Avatar
Yes, that is correct.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
Neil1664
Jan 20, 2022 08:59 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
jfitzoz
Sep 7, 2015 04:28 AM
