XJ40 engine in a Series 3
Old Jan 8, 2023 | 11:15 AM
claudesr's Avatar
Default XJ40 engine in a Series 3
Is it possible to fit an XJ40 (AJ6) engine and gearbox into a series 3 without modifications?
Anyone done it?
Claude
Old Jan 8, 2023 | 01:36 PM
icsamerica's Avatar
Anyone done it?
Claude
Not easy, it will fit but you will have to make and cobble together many solutions like motor mounts, radiator, hoses and supports.
The killer app is to use a AJ6 or AJ16 from a donor XJS. This way will be shockingly easy. It will be as if jag intended to do this themselves. radiator, coolant hoses, a/C lines will all fall into place with minor modifications. Most items will bolt in place with no changes at all. You can even use the complete exhaust system from the XJS with a few mods. This works out becasue the XJS is an evolution of the series 2/3 XJ platform. You will need a custom length driveshaft when using an XJS as a donor, the front 1/2 of you existing drive shaft will need to be shortened a few inches. This way you can train the XJ's 2 piece and the smooth running.
Old Jan 9, 2023 | 03:55 AM
Wilfred88's Avatar
My daily driver is a series 1 xj6 with 4.0 liter aj6 engine from an xj40.
so yes, its possibly. but nothing goes without any modification.
Old Jan 9, 2023 | 08:59 AM
Larry Louton's Avatar
Hello, I did a AJ16 Supercharged engine with GM 4l80 automatic transmission into 1985 Series 3 chassis. A lot of items bolted right in with some modifications. Power steering hoses had to be lengthened. Transmission cooler location modified. Intercooler modified. Shortened driveshaft. A/C condenser from a XJS. A/C hoses from 1995 XJ6 went right in. I could go on and on but the end result was worth it.
Larry Louton
Old Jan 11, 2023 | 01:33 AM
Michael AU's Avatar
@Larry Louton how did you go fitting the 4L80, They aren't a small transmission.
Old Jan 11, 2023 | 09:47 AM
The opening size of the tunnel is large enough to fit the 4L80. it is a tight fit but it does fit. There is another story going on now in this Series 3 forum where the man is fitting a Jaguar 6.0 V-12 into a Series 2 Vehicle which has the same Transmission as my car. I give him a lot of credit.
Larry Louton
Old Jan 11, 2023 | 09:53 AM
https://www.jaguarforums.com/forum/x...4-xj12-264643/ It is being done as we read. Series 3 and Series 2 have the same basic chassis.. This a good read into how to do it.
Credit given to Bullitandy.
Larry Louton
Wilfred88
Sep 3, 2025 03:30 PM
Wilfred88
Dec 2, 2021 02:26 PM
MarylaLuna
XJ40 ( XJ81 )
Apr 28, 2014 10:31 PM
Walter1982
XJ40 ( XJ81 )
Mar 12, 2010 12:49 PM
Walter1982
Mar 3, 2010 07:46 PM
