@#&ing LED bulbs
Old Mar 20, 2020 | 05:21 PM
VancouverXJ6's Avatar
Default @#&ing LED bulbs
Good thing I bought a 2quart sized can of beer today.
Doing an LED conversion on interior/exterior lights, one mistaken order at a time, because the supplier can't possibly list anything properly on their website. Can someone with a clue please confirm that:
https://www.superbrightleds.com/more...rofit-car/197/
Is in fact the correct wedge type bulb to go in the OEM large/green gauge cluster plastic sockets? (not warning lights) I'd rather not have to do a 3rd order.
I'll also post pictures of my LED reverse lights they are such an improvement!
Old Mar 21, 2020 | 03:20 PM
jag-reflex's Avatar
Default if it's any help
I used these. if your 'green lens' is good they work fine and just fit (in my '87). The bulb number is 194 but watch out for different bulbs with the same number. i can get you an amazon.ca link if you're keen..
Old Mar 21, 2020 | 08:32 PM
Can you send the link? Rather that then another US order now that the border is closed can't zip down for a domestic parcel pickup.
Old Mar 21, 2020 | 09:10 PM
Rescue119's Avatar
https://www.superbrightleds.com/vehi...1780&year=1988
So u searched for the vehicle right? None of these worked? I've used this site before with great results. Planning on ordering for my jag soon
Old Mar 22, 2020 | 08:43 AM
jag-reflex's Avatar
Here you go:
LED's LED's
Old Mar 22, 2020 | 01:17 PM
ptjs1's Avatar
I know there's lots of different quality in LED bulbs, but is there something special about those Philips bulbs? At $34 for two, they seem incredibly expensive. I thought T10 LEDs started from about £1 each?
Paul
Old Mar 22, 2020 | 02:22 PM
jag-reflex's Avatar
Paul
No idea. I know they work, that's about all I cared about. I've had them in for 2 years now without issue. My thought was that if i never had to pull the dash apart again they were cheap!
Old Mar 22, 2020 | 03:17 PM
Yes, most of their stuff has fit so far but the gauge cluster is swing and a miss every time.
Old Mar 22, 2020 | 04:21 PM
Dukejag's Avatar
I to would like to do this upgrade.... how easy is it?
How many bulbs do you need?
Old Mar 22, 2020 | 04:35 PM
Rescue119's Avatar
Old Mar 22, 2020 | 04:41 PM
jag-reflex's Avatar
4 bulbs in the main cluster. Easy? Well it's not horrendous but a very gentle approach is the safest because breaking the traces on the electrical would be a serious pain. As with a lot of XJ-S stuff, patience is the key. While you're in there you'll likely want to clean up ground connections etc., and make sure gauges are all good. For me, once was enough so spending on what is hopefully a quality LED bulb was a no brainer.
Old Mar 22, 2020 | 09:49 PM
Add a second ground wire if going through the headache of taking out the cluster. Your gauges will thank you.
Old Mar 23, 2020 | 11:11 AM
Rescue119's Avatar
good to know.
Old Mar 23, 2020 | 05:20 PM
Rescue119's Avatar
I'll let you know how I make out.
Rossy
Jul 20, 2021 12:26 AM
Hex Type
Apr 21, 2020 05:49 AM
JayYu
Jan 27, 2015 09:49 PM
flyrr100
Nov 3, 2014 01:54 PM
JagXType620
Jul 29, 2009 05:24 PM
