1995 Fog Lights - Shorting plug location
Old Jun 18, 2018 | 08:33 PM
Croz's Avatar
Default 1995 Fog Lights - Shorting plug location
OK, I know there was a full discussion about activating the wiring at the front fog light location ... please humor this old guy, I guess I just don't get it! .
I want to mount a set of aftermarket fog lights on my '95 XJS L4 2+2 Conv. There were none mounted originally. I have purchased an aftermarket 94 95 96 Jaguar XJS front fog light shorting plug/harness on eBay. Now just where the heck does this harness go? Is there anything else that needs to be done to activate the existing fog light wiring? Thanks for your patience.
Old Jun 18, 2018 | 10:29 PM
malc4d's Avatar
https://www.jaguarforums.com/forum/x...s-96086/page3/
read from post #41
Old Jun 19, 2018 | 10:24 AM
RonaldP's Avatar
If you replace both switch sets as in the post link above and install the shorting plug in the connector above the left inside fuse panel to the matching plug, you should have all you need. The relay and fuse are already installed at the factory. The front fog light, when switched on, will light while in low beam headlight operation. If you flash your high beams the fog light, by design, will turn off.
Old Jun 19, 2018 | 11:03 AM
Croz's Avatar
Thanks for the encouragement RonaldP. Is there a site that has these replacement switches? Not the solid gold switches, just the reasonably priced ones. - Cheers, Steve
1995 4L 2+2 Conv Metalic Topaz
Old Jun 19, 2018 | 09:37 PM
malc4d's Avatar
https://www.ebay.com/sch/i.html?_fro...uar+xjs+switch
Old Jun 19, 2018 | 10:01 PM
Croz's Avatar
Thanks malc4d - grabbed em!
Old Jun 29, 2018 | 11:56 AM
Croz's Avatar
FYI "Jag Services" has just cancelled that order for that set of fog lamp switches. No reason was given. Full refund was provided,
Back on the hunt for a set of switches.
Steve
Old Jun 29, 2018 | 01:53 PM
Jagboi64's Avatar
Did you try David at Everydayxj.com? You might have to call/email if it's not on his website.
Old Jul 22, 2018 | 03:46 PM
Croz's Avatar
I still have not been able to locate the fog light switch set. Does someone know if DAC10203 and DAC10106 are identical parts?
Cheers.
RonaldP
Feb 18, 2021 11:00 AM
genec
Oct 24, 2017 06:42 PM
Shelby676
XJ40 ( XJ81 )
Jun 6, 2011 09:15 PM
Jaguareh
Sep 18, 2010 06:42 AM
