1996 xjs minor projects
Old Jul 16, 2023 | 07:11 AM
Softball60's Avatar
Default 1996 xjs minor projects
To all,
Now that I have my cat running excellent I just have a couple of minor things to pick at……GIVES ME SOMETHING TO DO!!
then I might put it up for sale? Had offer last year of $14.5K….after seeing what goes for more money I decided not to sell.
CAT IS UNBELIEVABLE FOR 114K miles. PURRRRRRRRRFECT IN EVERY WAY!!!
MINOR ISSUES
1. Air conditioning works great as I rebuilt the system several years ago..NO LEAKS COLD AS ALL GET OUT!!!
BUT…. For some reason when I switch the fan Mtr. Speed to 1 or 2 it doesn’t seem to blow as hard through the eye height duct on the dash. When I switch to 3 high it BLOWS GREAT THROUGH THE SAME EYE HEIGHT DUCT. It sounds like on speeds 1 and 2 the right side blower motor is not on but on 3 it is???
LOOSE WIRE ?? HOW DIFFICULT TO CHECK OUT RIGHT SIDE MOTOR WIRING?
2. Driver side lumbar support is not filling up. Repaired this about 8 years ago….time for another look see!!!!
MAYBE HOSE CRACKED AGAIN??
MY MAIN CONCERN IS THE AIR CONDITIONING DUCT MOTOR.
Any insight is appreciated
Softball60/Paul
Old Jul 16, 2023 | 09:39 AM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...p-48306/page2/
This thread should get you pointed in the right direction for the AC Blower mystery.
As for the the lumbar, I had the same issue, but I did not need to return to the chair. What is your problem? My air pump works, but the bladder either has a leak or a failed one way valve because the air gets pushed out of the bladder. I'll fix it if I ever have a need to get back in there.
mghirsch
Sep 1, 2022 08:54 AM
jcuba53
Jun 7, 2015 09:34 PM
95XJRBlack
Apr 9, 2014 08:41 PM
kaniela
XJ40 ( XJ81 )
Jul 18, 2011 03:10 AM
Jan 20, 2011 04:14 AM
