6.7L V12 build
Old Mar 30, 2018 | 04:57 AM
  #441
warrjon's Avatar
When the second water rail is finished I will start on making aluminium 1/2 moon seals.
Stay tuned................
Old Mar 30, 2018 | 05:49 AM
  #442
xjsv12's Avatar
The aluminium half moon on S-type V6 first generation , with a small modification.
Old Apr 2, 2018 | 07:21 AM
  #443
xjsv12's Avatar
Alum insert half moon part number XR85240
https://www.britishparts.co.uk/jagua...d-insert-p6553
Old Apr 16, 2018 | 04:34 AM
  #444
warrjon's Avatar
Got my new milling machine set up and finished shortening the inlet valve stems. The digital quill depth gauge made this much quicker.
I'm off to Melbourne on this Saturday with the heads for Norm to bolt them on. Hopefully not too long now I'll have the engine back.
Old Apr 16, 2018 | 01:21 PM
  #445
LongJohn's Avatar
Hey Warren, Very exciting. I’m watching, learning and enjoying. Good luck John
Old Aug 30, 2018 | 02:59 AM
  #446
warrjon's Avatar
I know I haven't updated this for a while, I have been buying tools in order to make a few bits and pieces, on the todo list are custom intake manifolds, Aluminium 1/2 moon seals. Also Norm has been unwell so progress has been slow. I now have full inhouse machining capability. If I had this mill earlier I would have done all the machining. this will will fit a V12 engine block on the table.
Plan is as soon as I have the mill running are to fabricate new intake manifolds that look stock
A good ol pommie lathe
Yes that is a 6' ladder behind the mill
Old Aug 30, 2018 | 04:50 AM
  #447
Daim's Avatar
Awesome! Looking forward to seeing the results. I assume you'll be welding some alloy tubes to a nice sized plenum to replicate the original look?
Old Aug 30, 2018 | 06:35 AM
  #448
warrjon's Avatar
I was thinking of fiberglass plenum and runners fixed to an aluminium flange. Plenum will have aluminium molded in for TB mounts.
Old Aug 30, 2018 | 12:06 PM
  #449
LongJohn's Avatar
Sounds brilliant. Can you taper the fiberglass runners?
Old Aug 31, 2018 | 03:30 AM
  #450
warrjon's Avatar
I was thinking about that but after doing some research tapered runners are probably not going to add anything in my engine, so most likely straight. I was thinking how I will mold , them, probably use a PVC pipe and bladder.
Old Aug 31, 2018 | 11:56 AM
  #451
LongJohn's Avatar
Warren check out this plug...
Mabye a plug made from copper pipe would be easier and use carbon fiber sleeving instead of the stuff he used.
Old Aug 31, 2018 | 05:40 PM
  #452
warrjon's Avatar
Yes I saw that one.
This is the way I was thinking, like they make bike frames
DIY How to Carbon Fiber Tubes & piping for Intakes how to ~ Carbon Fiber Fiberglass DIY how to Guides
Old Sep 3, 2018 | 02:40 PM
  #453
LongJohn's Avatar
Warren you have some serious machines and skills.
Yes I saw that one.
Old Mar 19, 2019 | 09:30 AM
  #454
Addicted2boost's Avatar
Any updates on this engine?
Old Mar 19, 2019 | 03:03 PM
  #455
warrjon's Avatar
Norm was ill for a while which stalled the build. I had lunch with him Monday and the pistons are done and ready to start assembling the engine.
I will update as things progress. I have not abandoned this project, way to many $$$ in it now.
Old Mar 20, 2019 | 12:36 PM
  #456
Fla Steve's Avatar
Totally impressed with your machine shop. You are a machinist as well as an electrical engineer.
You Daa Man as they say!
Old Mar 20, 2019 | 03:07 PM
  #457
warrjon's Avatar
My trade is electronics and I grew up in a machine shop, my dad was a tool maker and had his own injection moulding shop.
I just love designing, making and repairing thinkgs
Old Feb 9, 2020 | 06:27 AM
  #458
Any more movement on this project?
Old May 1, 2020 | 12:10 PM
  #459
Jonathan-W's Avatar
Smile
hey
have not heard from you in awhile... I hope this message is finding you well in these trying times...
Jonathan
Old Feb 17, 2021 | 08:30 AM
  #460
Updates??
