89 XJS GM 400 {shift kit]
Old Jul 23, 2015 | 08:01 PM
mtpckts's Avatar
From: collinsville,Ill-18 miles from downtown ST,louis
Default 89 XJS GM 400 {shift kit]
would you install a B&M shift kit Stage 1? i have the kit the car has 32,000 need to change fluid why not do a kit!
Old Jul 23, 2015 | 08:21 PM
Doug's Avatar
I would, yes.
If 'Stage 1' is the more mild/less wild choice, that's what I'd go for
Old Jul 23, 2015 | 08:39 PM
Typhoon's Avatar
A stage 1 kit will be quite mild. Typically they just firm up shifts a little and encourage earlier downshifts. An enthusiastic driver would consider a stage 1 shift kit how an automatic transmission should be.
I've fitted a few to various cars over the years and always been happy.
Old Jul 23, 2015 | 09:51 PM
JagZilla's Avatar
This is what I installed in JagZilla when she still had the Turbo400 in her.
http://www.summitracing.com/parts/trg-400-1-2/overview/
I had firm shifts when I wanted them, and soft shifts when I was just cruising. I was also able to upshift and downshift at will, and hold 1st & 2nd gear past redline.
Old Jul 23, 2015 | 11:13 PM
JTsmks's Avatar
That's whats in mine now along with the B&M adjustable vacuum modulator and my kickdown set to "kick down" at 3/4 throttle vice WOT. Makes the car w-a-y more fun to drive then the stock setup.
Old Jul 23, 2015 | 11:52 PM
Safari's Avatar
I'm having a hard time finding the shift kit I want.
Why you ask?
Because I want the shifts to be softer, not harder. I want the shifts to be completely unnoticeable. I don't want to feel the transmission shifting at all, just smooth acceleration.
Does such a kit exist?
Mark
Old Jul 24, 2015 | 02:26 PM
Brake buster's Avatar
Why you ask?
Mark
yes
its called an original Jaguar spec GM400 box
if yours is shifting and your noticing it, then it probably wants a strip and rebuild replacing all bushings and any other worn parts, and all 7 ( yes 7 ) flow ball bearings need to be installed , i have reduced mine to 4 bearings, from memory a minimum of two are required for the box to still work , i also installed the adjustable vacuum , it now hangs on for higher revs for longer ,
in the UK a full strip and refurb at a gearbox socialist will cost £2k , they will also warrantee the box for that
i rebuilt my own ( see thread ) for under £500.....
BB
Old Jul 24, 2015 | 08:29 PM
mtpckts's Avatar
Talking JagZilla !!!!!!!!!!!!!!!!
i like alot!!!!!!!!! one of these days ,check out youtube jag v12 theres a great built motor for a i think J13 . but JagZilla is on the prowl you go kitty!!!!!!!!! i have to see it someday maybe get a ride in it
Rivguy
Dec 4, 2020 07:55 AM
user 652867429824
Oct 28, 2015 10:18 AM
Bc xj
Sep 17, 2015 06:34 PM
1964Daimler
Sep 9, 2015 11:20 AM
SCMike
Sep 9, 2015 09:30 AM
