90 VJS Conv.
Old May 15, 2021 | 07:36 PM
mikebaker3's Avatar
Default 90 VJS Conv.
How do you remove the quarter window motor? I followed the instructions in Volume 4 of the XJS Service Manual 76.81.02 to Renew the Rear Quarter Window - Convertible but cant get anything to budge. I need to remove the motor assembly in order to assist in snaking the EFI main harness from the trunk into the passenger compartment.
I think that I have all the bolts securing the motor, but it will not budge.
Anyone have any words of wisdom?
R/H quarter window motor with what I think are all bolts securing the motor removed
Old May 20, 2021 | 05:40 AM
macdoesit's Avatar
Banned
What is a VJS
Old May 21, 2021 | 08:33 PM
mikebaker3's Avatar
A VJS is an XJS owned by someone that can't type.
Old May 24, 2021 | 08:03 AM
JayJagJay's Avatar
Don't know if you solved this yet BUT...
What I sometimes do when I get stumped is google an image of the part removed from the car. EBay is great for this as it will show many different angles of the part removed. In the link below you will find 9 or 10 images of the part off the car. Might be helpful....
https://www.ebay.com/itm/313062378035
Old May 24, 2021 | 09:00 AM
icsamerica's Avatar
The motor is bolted on the back of the regulator, those bolts are difficult to remove from the side shown. I've parted quite a few XJS' that have been wreaked and I've always had to remove the glass first to get the regulator out. Then once the regulator is out you can replace the motor but in your case access the harness path.
Old May 24, 2021 | 10:34 PM
Mac Allan's Avatar
Originally Posted by macdoesit
What is a VJS
Since it's a 1990, maybe it's a special MTV personality from the era when they featured music videos, which would indeed be a rare classic.
I'll show myself out.
Old May 26, 2021 | 10:55 AM
mikebaker3's Avatar
There was a fourth bolt not visible behind the top hydraulic cylinder. Once I removed that bolt, I was able to slide the regulator out of the track and remove the regulator and motor.
Regulator and motor still in place
The fourth bolt that I could not see
Old May 26, 2021 | 02:13 PM
brinny's Avatar
Well done. Where there’s a will there’s a way.
brinny
Apr 1, 2020 12:49 PM
rwolak
Mar 23, 2020 08:08 AM
Leod1948
Jul 15, 2017 12:08 PM
sidescrollin
Aug 7, 2013 06:27 AM
