91 XJS Convertible window adjustment
Old Oct 6, 2022 | 01:33 PM
Richgus's Avatar
Default 91 XJS Convertible window adjustment
Is there a way to adjust the upper limit on the door windows??? The glass on the passenger side goes up too high and won’t re-seal against the weatherstripping if you open and close the door with the window up.
I’ve held down on the up switch a few seconds and can here the clicking like it’s resetting the limit, but it is still too high once the door is opened.
my 01 XKR will drop the windows when you open the doors and raise them when shut. Is the XJS supposed to do this also??
Old Oct 6, 2022 | 02:51 PM
Vee's Avatar
Vee
No it isn't.
You'll have to pull the door card off and you should be able to find the window stop. On the facelift I think it was on the rear end of the door, the side of the glass closer to the rear of the car. It's a simple contraption that should allow for adjustment.
Old Oct 6, 2022 | 03:32 PM
Richgus's Avatar
Thanks once again!
Didn’t want to go there unless I had to.
got it washed and checking things off the list.
headliner is probably next. Think I saw one on eBay for $229. Saw a post where it was a nightmare. Hope mine goes better….
Old Oct 7, 2022 | 11:10 AM
Richgus's Avatar
I pulled the door card and can not find any stops for up or down limits. It makes a metallic clanking noise when it reaches its limits
the drivers door doesn’t make any such noise…
I don’t want to pull the other door card to see the difference unless I have to.
does anyone have experience here. Am I missing a part or parts?
Old Oct 7, 2022 | 06:48 PM
Richgus's Avatar
I finally gave up and pulled the drivers door panel / card so I could compare them.
Took me a bit but finally figured out the up and down stops. Sorry I didn’t take a picture, was rushed getting it back together so I could get it back inside for the night.
I was looking for stops on the guides. The stops are for the actuator arm. They’re located below the door latch handle. Right near the actuator. There are two slotted bolts with a locking nut. They’re located about 4-6” apart with top one directly above the other.
The slot allows you to turn the bolt that has the stop on it inside the door. The nut locks the bolt against the door sheet metal to keep it in place.
On my car on the passenger side, the lower nut was missing and the upper one was loose. I put the window where I wanted it at top and bottom locations, turned the slotted bolt to adjust the stop against the actuator arm and locked it in place with the nut.
I hope that makes sense and might be of help to someone else.
Old Oct 10, 2022 | 07:23 AM
Dukejag's Avatar
Great thread - thanks - my passenger window does the same drives me nuts!
I will try this out!
Alexv12
May 10, 2019 09:04 PM
JagRag
May 28, 2016 09:26 PM
Alexv12
Jul 27, 2015 02:30 AM
Skid Mark
Sep 3, 2010 09:54 PM
