92 XJS 5.3 V12 thermostat replacement
Old Jul 9, 2022 | 07:43 AM
vadim_gershon's Avatar
Hi Grant, thanks for the doc. I can now fully understand how the thermostats are supposed to work.
I am currently rebuilding a 1986 XJS V12. In going over the cooling system I have found that the bypass ports in both thermostat housings are neatly blocked by welch plugs in a way that looks factory made. I have also found that both old and new thermostats are 3 to 5mm short of blocking the bypass ports anyway. What do you think I should do about this?
Old Jul 10, 2022 | 02:40 AM
Greg in France's Avatar
If you have an HE engine, then those blanks should be removed and the correct thermostats fitted.
Old Jul 10, 2022 | 05:12 AM
1) Alcohol, lots of it, DAMN.
2) I answered your Private Message not long ago.
3) Find the Wombat that did that and string him up.
SuperCheap, Bursons etc etc.
Obviously REMOVE those plugs.
Old Jul 10, 2022 | 07:56 AM
Thanks for the advice Grant. I will probably have to drill them out.
Regards,
Vadim.
Thanks Greg, will do.
Regards,
Vadim
Doug
Feb 27, 2019 01:31 AM
71 MKIV
Jul 24, 2018 12:59 PM
JigJag
Nov 16, 2016 06:49 AM
Curtiss James Woosley
Nov 20, 2015 01:31 PM
Daim
Jun 21, 2014 01:07 PM
