ab14 ignition amp
Old Jun 22, 2018 | 11:02 AM
Romel420's Avatar
Default ab14 ignition amp
How will i know if my ab14 ignition amp is working or working properly. Is there a way to bench test this unit ? What is the best place to relocate this amp ? . What wire gauge should i use if a relocate this (i assume that an extra wiring is needed).
thank you
Old Jun 22, 2018 | 11:27 AM
rgp's Avatar
rgp
What I have read is where it is is not a problem and if the car runs there is no problem with it. If you look for trouble on an old xjs you wont be disappointed. Lol
Old Jun 22, 2018 | 11:43 AM
Jagboi64's Avatar
I don't think there is a way to test those. Inside it's GM 4 pin HEI module, so you can look and see if there is a test for those. They tend to either work or they don't.
Don't relocate the amp. It generates quite a bit of heat, and where it is is actually the coolest spot in the engine bay. The incomming air through the intake manifold acts as a very effective cooler. If you've ever driven a V12 in winter ( as I have) the engine block will be hot and the intake manifolds are very cold.
Old Jun 23, 2018 | 08:31 AM
J_C_R's Avatar
When they stop working, you'll know, as the engine will stop running and won't start until you replace the amp.
You only need to replace the HEI module. My experience has been that it's hit-or-miss on if a new module will work or not. I bought four, two of which worked and two which didn't. So I carry a working spare in the car. Being a GM part, they are fairly easy to find.
Old Jun 23, 2018 | 09:14 AM
Greg in France's Avatar
FWIW, I am a fan of relocating the amp to a cooler spot.
Old Jun 23, 2018 | 12:04 PM
Jagboi64's Avatar
Were they all genuine GM parts? I have not had an aftermarket amp work yet with the V12, it needs to be the genuine GM part. I take them from the junkyard when I see them and not had any trouble with them.
Old Jun 23, 2018 | 03:07 PM
J_C_R's Avatar
Yes, they were all new-in-box (how "new" I don't know) GM parts. I got my money back on the two which didn't work, so it wasn't a big deal.
I've never tried an aftermarket module.
Thanks,
John
Old Jun 23, 2018 | 03:15 PM
JigJag's Avatar
I just installed this NOS HEI Performance Ignition module for GM Cars 1974-1988 and Aftermarket Race Distributors. Supposed to provide a bit more dwell. We shall see. The good news is that she fires up nicely and revs smoothly with it. Some, as others have said above, simply don’t run the v12 at all.
New old module
Brian Felts
Dec 15, 2017 06:23 AM
rgp
Jan 12, 2017 07:21 AM
rgp
Oct 27, 2016 01:34 PM
rgp
Detailing / Car care
Oct 25, 2016 12:25 PM
Ratfink
Jul 10, 2015 06:08 PM
