AC Delete
Old Oct 11, 2016 | 07:50 PM
jagpaw's Avatar
Default AC Delete
Hi guys, going through a lot of work on my '90 XJS conv. So I've pretty much decided to delete the AC. Mainly because it doesn't work, hasn't worked in years and I live in western Pa mostly only take the car out in nice weather. I understand the defrost won't work as well and am willing to accept that. The bigger question is the fuel cooler. Can I add a aftermarket fuel cooler on the supply side to correct deleting the factory one? If my AC hasn't worked for some time and I never had a vapor lock issue should I even worry?
Old Oct 11, 2016 | 08:29 PM
baxtor's Avatar
Personally l would not worry about the fuel cooler aspect. At worst there may be the odd occasion where you may need to cycle the pump for a hot start situation.
Old Oct 11, 2016 | 08:40 PM
JTsmks's Avatar
IIRC the fuel cooler is not on the supply side but is on the return side. It cools the fuel that is returning to the tank.
Old Oct 12, 2016 | 02:19 AM
Greg in France's Avatar
True.
Jagpaw:
And if the A/c has not worked, there has been no fuel cooling, so do not worry about it. Either remove and replumb the fuel that is currently routed through the (not cooling) cooler, or leave the cooler in place but (obviously) with no a/c hoses to it and leave the fuel routing as it is. Apart from cleaning up the engine bay, it makes no difference.
Later V12 engine were not fitted with a fuel cooler even by the factory.
Greg
Old Oct 12, 2016 | 03:01 AM
warrjon's Avatar
IMHO, the fuel return pipe runs under the car in an area that will keep the pipe cool. I would delete the fuel cooler anyway.
Old Oct 12, 2016 | 05:29 AM
jagpaw's Avatar
Yes I understand that. My question is would it be better to add an aftermarket to the supply side. Seems to be a popular upgrade to performance cars in general.
Old Oct 12, 2016 | 05:33 AM
An aftermarket what, Jagpaw?
Greg
Old Oct 12, 2016 | 05:42 AM
jagpaw's Avatar
Greg
I'm sorry, an aftermarket fuel cooler on the supply side
Old Oct 12, 2016 | 05:46 AM
What will do the cooling if there is no A/C? Regardless, you do not need it, that is for sure.
Greg
MarlboroughMotors
Jun 11, 2024 04:13 AM
absoluteze
Apr 26, 2024 10:02 AM
orangeblossom
Sep 2, 2016 03:46 AM
jpitma1
Sep 1, 2016 01:35 AM
carzaddict
Aug 27, 2016 12:18 PM
