Adding remote locking "how to" FAQ
Old May 27, 2020 | 09:06 PM
CZSteve's Avatar
So interesting side bar if OK for a slight thread high-jack...
So I'm on Amazon in the automotive section and have 1978 Jaguar XJS entered for my garage to narrow down selections and lo-and-behold the XJS picture that Amazon is using is @ronbros Jag - pretty cool.
Old May 28, 2020 | 02:00 PM
ronbros's Avatar
i been sayin that for years!
put any factory stock XJS at a car show beside mine , and just watch the people stop and look and ask questions!
and to think i did that 26years ago!, did i mention its pretty fast also!
steve thanks for lettin me know!
Old May 28, 2020 | 02:57 PM
Duke85's Avatar
LETS SE THEN!!!! Lots of photos and details of your enhancements
Old May 29, 2020 | 10:00 AM
ronbros's Avatar
pix will never take place of real life, a completely different visual reaction!
cars side by side makes a difference!
where the heck is Derby??
Old May 29, 2020 | 05:57 PM
JayJagJay's Avatar
Default What about the 1990
Hello all. This is definitely on my list, too...
Does anyone know what the cut off is. Meaning the relays vs the ECU control? I guess I could and should just go into my doggone 1990 electrical guide, bit thought I would just ask you guru's...
EDIT: I think I found my answer... Thanks for all this info non the less.
Old May 30, 2020 | 05:54 AM
Duke85's Avatar
Where is the door lock control unit on a left hand drive car? Derby is a place you don't need to know about
Thanks guys
Old Jun 30, 2020 | 01:25 AM
imitch1303's Avatar
Hi Duke85,
Check out Doug's earlier posts (#11 and #13). There is not a single control unit on your car. There are two relays (lock and unlock) that control the solenoids in your doors.
Cheers,
Ian.
Old Jun 30, 2020 | 10:43 AM
  #28
Duke85's Avatar
I got it to work in the end! Success!!!!! I figured it out through trial and error
Old Jun 30, 2020 | 10:45 AM
Duke85's Avatar
All the wires were on the driver side.
Old Jul 12, 2020 | 07:51 AM
  #30
lambo911's Avatar
Hi,
I have just put this system on my 92 V12, https://www.ebay.co.uk/itm/373097262454 it has nice remotes that just to door open, close.
I just used the security system plug in the boot and was easy once I had worked out which wires to use on the new controller. My car was negative polarity too.
Function / Jaguar harness
Live / Brown
Ground / I used the ground bolt near the light
Lock / Orange/Red
Unlock / Orange/Blue
I couldn't wire up light flash as it works the other way, i.e. it gives a 12v pulse but what you need is it to ground.
Works a treat. Frozen locks in the winter are no longer going to be a problem !
Old Jul 12, 2020 | 08:09 AM
  #31
Duke85's Avatar
Great well done. Mine is all under the D/S dash as I have an older model. But yes it's really made a huge difference. I use my car daily and this feature really brought the car into the 21st century!
Asdrewq
Aug 11, 2016 06:18 AM
AfricanJag
Oct 10, 2014 04:13 AM
BadDog
Nov 23, 2013 10:38 AM
jjf
Oct 23, 2013 04:30 PM
BKSinAZ
Mar 11, 2010 12:56 PM
