Aftermarket (temp) gauges? (Realguage vs. Bluetooth)
Old Jun 10, 2018 | 10:42 AM
neuroticartist's Avatar
Default Aftermarket (temp) gauges? (Realguage vs. Bluetooth)
Hi everyone, I've read several conversations on the forums about realgauge and Bluetooth gauges (Panlong Bluetooth OBD2 on Amazon). Problem is, these conversations are for later model cats.
I've got an 1984 XJS with a Chevy LT1 under the bonnet and my gauges, of course, don't tell me much. I overheated the other day and now that summer is coming, I worry about being able to monitor the temperature. Other options would be nice too.
Does the realgauge work on older Jags? I'm really interested in the Bluetooth, having one set up on an android tablet would be the best option for me, but is it possible? I wasn't able to find an OBD1 version of Bluetooth adapter.
Any insight and opinions are greatly appreciated! I'm open to any other options and possibilities as well, so if you have done something different, Id love to hear it.
Old Jun 11, 2018 | 12:46 AM
baxtor's Avatar
A 1984 xjs is not going to have any version of OBD. Most practical way of getting working gauges might be to adapt the original jag senders to your Chevy motor and utilise the original gauges.
Old Jun 12, 2018 | 03:39 PM
Im not sure I understand your reasoning, I recently replaced a knock sensor that went bad and tracked it down by using an ODB1 scanner.
Old Jun 14, 2018 | 04:04 AM
bladerunner919's Avatar
The reasoning is that no standard XJS of that year would have any ODB systems. However, your car isn't standard, of course - I assume you have a second gen LT1 with OBDII?
Old Jun 15, 2018 | 08:20 AM
turns out, you guys are correct, my current ecm does not support or does not monitor eng coolant temp, oil pressure, etc. So does anyone have any suggestions for older school gauges that you've used?
Old Jun 15, 2018 | 08:39 AM
carid's Avatar
Former Sponsor
Most of the old school gauges that we sell require a regular mechanical sender, so you can find a custom sender for the gauges on your dash or custom fit new gauges with classic design. You can check our section of standard and aftermarket gauges, perhaps you'll find something interesting for your XJS:
https://www.carid.com/custom-gauges.html
Old Jun 15, 2018 | 09:41 AM
Doug's Avatar
Are you aware of any aftermarket outfit making a tachometer for 12 cylinder engines? I've looked, briefly, but came up empty.
Old Jun 15, 2018 | 05:55 PM
VancouverXJ6's Avatar
These guys might have something.
https://www.intellitronix.com
Lots of sensor units and universal LED display kits.
Old Jun 17, 2018 | 09:22 AM
44lawrence's Avatar
I got rid of that "trip computer" and put three Auto Meter gauge's in there. Two coolant & a oil pressure. The two temps have the sensors in each water rail via weld in bungs. I can't speak for your engine but the concept of keeping an eye on your engine would be the same
Fstbmw1
Mar 25, 2015 08:23 AM
OGDuarte
May 29, 2014 06:58 AM
REIguy
Jun 1, 2013 06:16 PM
