Is the alldata subscription worth it for the 96' XJS?
He replaced my Inboard Rear Calipers, Rotors, pads and E-pads. Diff seals and bearings were replaced, along with Rear Coil Springs, and all (6) Koni Shocks. He replaced the Trans. mount spool bushing, Trans. filter and fluid.
Moving to the front of the car, I had him replace the Sparkplugs, Dist. Cap and Rotor and Wires. Lastly was the Coolant Hoses. I had bought all these parts over the summer, and thought it best to have it all done at once, while in the shop with the hoist.
He chose to drop the complete rear cage, saying he wanted to see what he was doing properly.
When he was finished, I asked him if anything gave him trouble, he replied he had all the info in front of him, and would not have done the work without the AllData program.
My approach with the XJS is that you can never have too much information on it.
I have everything, ie ROM, JDHT CD, alldata.
I have found all data to have unique info inside. I think it's cheap, ie less than one hour labor charge
What is ROM?
He replaced my Inboard Rear Calipers, Rotors, pads and E-pads. Diff seals and bearings were replaced, along with Rear Coil Springs, and all (6) Koni Shocks. He replaced the Trans. mount spool bushing, Trans. filter and fluid. Moving to the front of the car, I had him replace the Sparkplugs, Dist. Cap and Rotor and Wires. Lastly was the Coolant Hoses..
Just kidding around.
