Aluminum half moon seals source
Old Mar 11, 2021 | 10:16 AM
Rescue119's Avatar
Default Aluminum half moon seals source
I thought I found a source for the half moon aluminum but the websites are a wee bit dodgy. It's like it's the same place but different sources. Anyone have a verified place from recently. Like past year or so? Preferable this side of the pond?
Old Mar 11, 2021 | 01:55 PM
jal1234's Avatar
The guy in the link below is great. I've gotten all kinds of parts from him. He's been around awhile, and frequents the Jag-lovers forums. Very reliable with high quality parts.
https://www.ebay.com/itm/Jaguar-V12-....m46890.l49292
Old Mar 11, 2021 | 02:13 PM
Rescue119's Avatar
Ok those are the same ones I've seen. Wasn't sure. About 110cdn shipped ugh lol
Old Mar 11, 2021 | 02:17 PM
Greg in France's Avatar
Rescue
They are good, but Grant swears by the standard OEM rubber ones, which if fitted as he recommends, will see you out!
Old Mar 11, 2021 | 02:18 PM
Rescue119's Avatar
Rescue
Did he do anything special to them? alread read about filling it up with something like jb weld
Old Mar 12, 2021 | 01:43 AM
PM him, and I will try to remember to ask him as well. I seem to remember he just uses some hi-temp silicone stuff on the curved part and a smidge of it on the top surface; but am not quite sure.
Old Mar 12, 2021 | 03:23 AM
Message received.
I used the OE half moon on all the V12 and XK 6 cyl engines.
Nothing special, beer I suppose, but the job is not that long since you have it apart now.
CLEAN the tappet block groove, CLEAN it again.
Hi Temp RTV. I used the Red, as thats all that was out there back in those days. Now, I am told there is Grey, Blue, Black.
A goodly smear, enough to ooze out, on the curved section, place them in the tappet block, a smear (as a dressing) on the top face, and fit the Goretex gasket, and the cam cover.
Wipe away the ooze before it dries, jobs done.
Reality is the OE have lasted 30+ years, and the lousy caretaking the car has tolerated, and never really caused that much grief.
My XK engines, looooooong before the V12's arrived, were done the same way, and are still dry.
Adding to that, I dont use gaskets here, just a bead of Hi Temp RTV, guide suds for setting the cover up, and NO more leaks ever.
Old Mar 12, 2021 | 04:34 AM
Rescue119's Avatar
Originally Posted by Grant Francis
Message received.
Thanks Grant and Greg.
Old Mar 13, 2021 | 07:27 PM
VancouverXJ6's Avatar
Just dont do what I did and order 2 thinking price was 1 each. Ohwell SomeDay from Japan got my second set and both are perfect no leaks no bs. The ebay guy does good stuff I occasionally try to bribe him to make more stuff for the v12.
Old Mar 15, 2021 | 10:10 AM
rgp's Avatar
rgp
**** up. Should have gone on another topic 😊
Old Mar 15, 2021 | 10:17 AM
Rescue119's Avatar
Originally Posted by rgp
Having previously fitted the later illuminated vanity
sunvisor to my HE I thought there must be away to hide the 3 fixing screws
so I purchased 2 S type covers covered them in leather and glued them into place. 😊😊
Umm not what we were discussing lol
Old Mar 15, 2021 | 04:55 PM
Asdrewq's Avatar
One thing to note - with th eOEM rubber seals, if the cam cover gaskets you use are the better more modern style rigid metal/black rubbery goretex stuff 'sandwich', then you have to put sealant between this gasket & the half moon seal, & ALSO between the gasket & the cam cover, above the half moon.
These gaskets work fine between two pieces of metal with no sealant, but as the rubber half moon seals won't clamp the gasket hard , it needs sealant.
Old Mar 15, 2021 | 05:41 PM
Some Day, Some Day's Avatar
Yup. So far, all seems well there. Quality merchandise.
They're smaller than you might expect. And no one will ever, ever see that "Jaguar" logo once they're in place.
Old Mar 15, 2021 | 08:09 PM
jal1234's Avatar
Yeah, but YOU know that logo is there, lol!
Old Mar 17, 2021 | 09:25 AM
Rescue119's Avatar
Clutch fan removed.
If im replacing with electric fans do I need to remove the housing attached to the engine as well?
Old Mar 17, 2021 | 11:02 AM
Rescue119's Avatar
What I've removed so far today
So the air pump there wthere things attaches. That one hose that went to the airbox.
Then this hose the one on the right with the white stripe
It goes into a T which is connected to that sensor (pink top) on the right of it and also up the that area with the other hoses (trans vacuum) on the back of the RHS manifold.
What should I do with it?
And then this hard pipe that goes somewhere underneath.
Do I cap it? Or leave it open. I think it draws the warm exhaust as part of that 45 second timer thing.
Anyways I'll leave it and get to something else after lunch.
Old Mar 17, 2021 | 11:52 AM
Rescue119's Avatar
Ops wrong tread lol
Jon89
Jan 12, 2019 07:30 PM
Jon89
Feb 12, 2017 03:26 PM
SinF
Mar 24, 2016 06:39 PM
jaguar jon02
E type ( XK-E )
Oct 22, 2014 11:35 AM
Danny A Fish
Aug 17, 2014 12:45 PM
