Any V12 XJS's come with individual throttle bodies?
Old Jul 12, 2014 | 06:47 PM
AristoCat's Avatar
Default Any V12 XJS's come with individual throttle bodies?
I was told that all V12 jaguars came with ITB's.
It just sounds too good to be true.
But anything is possible.
Now I'm just trying to track down a set of 12 throttle bodies, for a project.
Any help would be greatly appreciated.
Old Jul 13, 2014 | 01:16 AM
Greg in France's Avatar
No car came from the factory for general sale with 12 throttle bodies. The carburetted cars - in effect - had two on each bank (four in total, one for each carb). The fuel injected cars all came with one on each bank.
What any aftermarket firms did is anyone's guess!
Greg
Old Jul 13, 2014 | 03:52 AM
Daim's Avatar
There is/was a Lister kit with four TBs...
Old Jul 13, 2014 | 06:41 AM
86jag's Avatar
Not fuel injected, but there are weber downdraft carb kits for the v12. These use 6 carbs and each carb has 2 butterfly's. So those in effect are like 12 carbs.
Old Nov 30, 2014 | 03:13 AM
Paul_59's Avatar
Banned
I realise your question was back in July and you may have got an answer.
If nor then a company called Jenvey make a kit for V12 Jaguar.
Made to order, Web site says two weeks delivery from placing order.
Definitely not inexpensive, priced approximately £3000 plus vat.
looks very desirable
http://www.jenvey.co.uk/home/throttle-body-kits/jenvey-dynamics/v12-jaguar-throttle-body-kit-sf45-ckjr04
Old Nov 30, 2014 | 04:46 AM
plums's Avatar
I know of someone selling a 6x2 mikuni setup for under $1000. Looks very nice, but they
did mention that it has never been actually installed.
Old Nov 30, 2014 | 09:20 AM
V12 Jaguar throttle body kit SF45 - Jenvey Dynamics
Quite, quite lovely, but will it need to be removed each time the plugs are changed?
Greg
Old Dec 1, 2014 | 03:55 PM
ronbros's Avatar
be an unusual air filter setup!
Old Dec 3, 2014 | 10:57 AM
Paul_59's Avatar
Banned
The more I think about this and consider this project the closer to succumbing to temptation.
The valid practical considerations raised by Greg and others regarding physical space limits, air filtration and need for ecu remapping to accommodate likely slight increase in air flow are problems that need a solution. Indeed Jenvey allude to tight space limitations in the fitting instructions for their kit ..."The kit fits very close to the cam covers and under the bonnet"
Incidentally could anyone confirm what if any differences there are between bonnet for 4.0 L and V12 bonnet (6.0l facelift in case it matters )
If someone would convince me that they could install this on anew XJS in a competent manner I may bite the bullet.
Also not directly related as it's from a marine application of V12 Jaguar engine
Old Dec 3, 2014 | 12:06 PM
The inline 6 cylinder bonnet had a hump in the middle to clear the upright engine. The V12 cars, pre facelift, did not have this hump. All facelift cars, regardless of engine, had the same hump bonnet. In any mod of this sort, using a later/6 cylinder bonnet must be a good idea as there will be a touch more space available in the middle 12 inches or so. Theer are no fixing changes apart from the catch, so just be sure you get a bonnet with the same shutting catch type.
As to Q2, drive it down to France and I will quote a very reasonable charge! Seriously, though, I could recommend a couple of very good independent Jaguar guys, but not that close the Wigan. I am sure so could loads of other posters from the UK.
As RB said, air filtration would be a problem. If Jenvey have no ideas, some sort of huge lightweight fabricated box with the trumpets poking into it, with a large diameter filtered feed from the front/headlight nacelles would seem to be the best option.
Greg
Old Dec 4, 2014 | 01:03 PM
sidescrollin's Avatar
lol they would have to be so much smaller than stock for it to not be super sensitive, 12 of the factory TBs would be so much air...
you would need a custom plenum anyways, so if you are going to make one, just find the appropriate sized throttle body off of something else, be it a small nissan engine, ford, etc, and hook that up. Have fun with the throttle linkage and vacuum hoses...oh and air cleaners.
If this helps you realize that it wouldn't do much....Imagine one bank with six cylinders, all with individual TBs and runners, and all with their own air cleaner directly over the TB. Now imagine if you made a chamber to go around all of the air cleaners that had a opening to the fender to feed air in, this would keep all of the air a consistent speed and temperature right? Do you think it would harm performance, or that it would be better to "breath freely" from the exhaust manifold?
Back up and shift the entire thing backwards a step, because that is basically what a single large throttle body is to a large manifold connected to several intake runners. So I don't see how it would be necessary or accomplish much. Was just trying to get you to see it in a different way. There is a reason cars don't have 4,6,8 throttle bodies, it isn't really helpful. You have to understand it IS helpful on carburated engines and this is different because the carbs can only provide so much fuel and atomize it to a limited degree, so while it is hard to get them all set up the same, there are benefits.
Old Dec 4, 2014 | 04:08 PM
superchargedtr6's Avatar
Try this:
https://www.borlainduction.com/2930-series.html
The problem with the Jaguar V12 and throttle bodies, as I understand it, is the short space in which to put a runner, or plenum(s). I think multiple TBs would be eye candy, I bet they would be horrible in the mostly stop and go driving a street car sees. High rpm? A whole "nuther" story as we say here in the south.
Old Dec 6, 2014 | 11:47 AM
cool. $5000 sounds like a bargain lol
tbird6
Aug 13, 2024 07:50 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
mrplow58
Sep 9, 2015 11:27 AM
