Brake issue XJS
Old 12-14-2015, 07:14 PM
kenatofc's Avatar
Default Brake issue XJS
A week ago, my anti lock light and brake light came on and I lost the "power" to my brakes. I have since checked the fluid level, the 2 30 amp fuses, and have even replaced the pressure switch (from a parts car)... The brakes still are hard when I push the brake pedal. The wheel sensors are ok. Where to now ??
Ken in WV
Old 12-14-2015, 07:30 PM
superchargedtr6's Avatar
Sounds like the accumulator has given up altogether. Seems these are getting kinda hard to come by since everybody figured out the GM one was a direct swap.
Old 12-16-2015, 08:31 PM
kenatofc's Avatar
thank, I hve one from a parts car and will switch it out !!! Forgot about the accumulator!!
Old 12-16-2015, 09:25 PM
Not sure swapping it out will do any good, but worth a try. Seems 11-15 years is about tops for them to last as it is a service item.
Old 12-20-2015, 06:38 PM
kenatofc's Avatar
another question.... what does the abs motor sound like when it comes on... i only feel a vibration but no sound ??
Old 12-24-2015, 03:14 PM
kenatofc's Avatar
got it !!!! sounds like a motor when a working accumulator is connected !!!
ken
Old 12-24-2015, 03:16 PM
kenatofc's Avatar
OK, finally figured out that both accumulators were bad. Broke down and bought one of the expensive ones on EBay $334.00 put in on and after the 60 second pause for pressure, it works, brakes work and we are on go.... now to reset the anti lock light on the dash !!!!
Ken
Old 12-24-2015, 03:24 PM
kenatofc's Avatar
BTW, before going broke buying the accumulator, I checked the two 30 amp fuses, the ABS module, the speed sensors on the rear and the combined pressure switch... All were ok.... That left the expensive part ...... but the cat can get back on the road... and in the auto show in Jan here in Charleston at the Civic Center.
Ken
Old 12-24-2015, 06:52 PM
Those accumulators are getting pricey. Can only hope that GM builds a batch of AC Delco ones for all of the GM cars that had them. I bought mine two years ago for a little under 100.00 under a GM part number.
mick99
01-14-2016 07:32 PM
Nerius
11-18-2015 05:08 PM
Alexv12
11-18-2015 12:24 PM
Blue_XJ8
11-16-2015 04:06 PM
Unhingd
11-16-2015 02:23 PM
Quick Reply: Brake issue XJS
