Brake reservoir float, is it just a simple on/off switch?
Old Mar 7, 2026 | 07:17 AM
Youngd59's Avatar
Well you’ve pretty much covered everything involved in the swap. If I could only find a DB7 pedal box my life would be complete. Before this thread, I didn’t know this mod was possible. Now I need to do it. 🤔
…Dean
Old Mar 7, 2026 | 09:04 AM
ptjs1's Avatar
Dean,
Maybe contact this guy Jaguar XJS LHD Clutch/Brake Pedal box NON ABS With new Cylinder & Pedal Pads | eBay UK
But you'd need to be clear about whether you have pre-ABS, Teves II ABS, or Teves IV ABS
Paul
Old Mar 7, 2026 | 10:22 AM
nickr76's Avatar
Thats not an oem pedal
box. The main reason I did this swap was to get the later style master and fluid reservoir. The aluminum pedal
box is unique to the db7 vantage. The ebay seller i used is regularly breaking DB7’s, i’ll bet he could get another.
i have a Jaguar Specialities converted lhd pedal box if anyone is interested. It wont work with the later master cylinder/fluid reservoir however.
Old Mar 12, 2026 | 08:57 AM
nickr76's Avatar
This project is beginning by to test my patience.
was having trouble bleeding the lines, figured it was airlock as master cylinder was drained. Tried every trick in the book, nothing.
turns out the master cylinder is toast.
my ebay “deal” is turning out to be less of a deal than I thought.
new master cylinder ordered. 500gpb later.
Old Mar 12, 2026 | 09:16 AM
Don B's Avatar
Originally Posted by nickr76
This project is beginning by to test my patience. Tried every trick in the book, nothing.
That is incredibly frustrating! When you said you tried every trick in the book, did you bench bleed the master cylinder? That is often the only way to get all the air out.
Cheers,
Don
Old Mar 12, 2026 | 11:02 AM
Greg in France's Avatar
As Don mentioned, if the M/C was new, it might need to be bled, i.e. primed. I have found the easiest way to do it is to fit it to the car, but do not attach the brake lines to it, place a GOOD load of rags under the cylinder and protecting the area, and then have a friend push the pedal down and hold it down, then you place a finger over each outlet on the M/C, pedal up which forces the M/C to pull fluid into it from the reservoir, repeat until fluid pumps out cleanly. Then attach lines and bleed the system normally.
Old Mar 12, 2026 | 02:04 PM
Don B's Avatar
If you're worried about getting brake fluid on your paint, you can get an inexpensive kit of adapters that thread into the pipe fittings on the master cylinder and allow you to run rubber tubes to feed the expelled brake fluid back into the master cylinder reservoir. Less than $10 from Amazon:
If the master cylinder is not installed in the vehicle, you can use a Phillips screwdriver to carefully depress the master cylinder piston to work fluid through the valves, or if you want to avoid the risk of depressing the piston too far, you can get a special tool with a limiting disc like this:
Cheers,
Don
Old Mar 12, 2026 | 04:59 PM
  #28
nickr76's Avatar
The Dorman m/c bleed kit is exactly what I used, it’s just not moving fluid. Pumped it for ages, pressure bled. I primed it on the car with the lines detached and the bleed kit routed accordingly. M/c was used, not new.
Old Mar 17, 2026 | 04:53 PM
nickr76's Avatar
All back together. Brakes are solid as a rock. Definitely less pedal travel than original set up.
Now if winter would be over I could try it.
Old Mar 21, 2026 | 10:50 AM
  #30
nickr76's Avatar
Took it for a spin, brakes are much better than before.
i suspect original booster wasnt holding vacuum as brakes are so much touchier now.
also you must make a cut out in hood insulation to clear reservoir cap.
still looks “factory”
Old Mar 22, 2026 | 06:23 AM
  #31
Youngd59's Avatar
Glad everything worked out Nick!
garethashenden
Oct 20, 2020 01:07 PM
Duke85
Jun 21, 2020 01:26 AM
Woznaldo
Aug 3, 2019 05:29 AM
burton512
Sep 21, 2014 04:35 AM
Boeingtravel95
Jul 6, 2013 11:50 PM
