Brembo Brakes on a XJS
Hi Chaps
Can anyone tell me, is the Brembo brake package used on the XKR transferable to a 95ish XJS / DB7?? With new wheels...
Am I right in thinking the XK was based on the XJS?
TIA
TIA
I seriously doubt it.
The "Floorpan" is what was always referred to as the "based on". Same as the Aston Martin, "based on" the XJ-S floorpan.
AGREED, some mechanicals changed camps, makes perfect sense.
The brakes, maybe?, but that would be a "suck and see" situation. Nothing is impossible, so probably do-able with some serious outside of normal thinking.
Benefits, mmmmmmm, minimal in MY opinion. These cars stop very well with decent OE spec rotors and pads, and CLEAN/FRESH fluid.
If you are tracking the car, or a "demon driver" then OK, different situation totally.
I tried, the XKR brembo's definitely will not fit. I worked on upgrading my brakes on the my XJ coupe for quite awhile. The only thing I know of that will bolt on is the DB7 Vantage Velonte caliper and rotors. The calipers are Brembo and the rotors are 13 inch. GOOD LUCK finding a set and if you do they will cost a fortune. Ohhh wait Here's a set...http://r.ebay.com/tyKGb5 I think. They look like Volante but I'm not sure. Perhaps a part number search may help ID them for sure.
I ended up custom fitting a set of Wilwood calipers with Wilwood Alu hat 12.2 inch rotors in the front and XJS vented convertible brakes in the rear. It was a major improvement.
https://www.jaguarforums.com/forum/x...e-works-84536/
Thanks for the input guys... AM did do a sport package for the I6 DB7 called the Driving Dynamics package with 19" wheels, big discs and Brembo 4 pot calipers, which is still getable from some places, but at over 6k!
Think I was just grasping at straws thinking the XK Brembo package might bolt straight on.... Never mind.
For me it wasn't that much of a deal because I've always believed that the OEM brakes on the XJS stop the car in excelent fashion. Of course, I also know that the fact that they work well wouldn't stop me from getting Brembo's, should they be available for my car... really a questionable choice knowing, too, that they are expensive to get and expensive to service/refresh...
Agreed. I recently had the brake fluid flushed on my wife's XK8 and the improvement in pedal feel was very noticeable.
i just finished a front brake upgrade, new hi-quality gold rotors, slotted and dimpled, rebild the Wilwood calipers. flush system, and added an electric vacuum pump, SS lines.
excuse the corvair engine shot, computor burped.
metalmarty
Sep 11, 2015 07:05 AM
