Cherry Blossom - Restoration 1990 XJS V12
Old Aug 9, 2014 | 08:19 AM
  #101
o1xjr's Avatar
Originally Posted by orangeblossom
Don't mind me Clarke
Jump right in, all this stuff is very interesting.
That's me, jump first then think later. Just thought some things painted with spray cans would fit here.
Old Aug 9, 2014 | 08:22 AM
  #102
ptjs1's Avatar
OB,
It's good that your rad company sounds to be a conscientious bunch. Bodes well for the final product.
I sense you're moving away from keeping your aircon but I'll leave you with just a few thoughts then I'll butt out:
- In the UK, a well-maintained V12 engine and cooling system won't overheat with aircon, even recognising the limitations of airflow. Your new rad will make a big difference and the car will run fine. If it did overheat, it won't be because of the aircon
- I view aircon as "air-drying" rather than a cooling mechanism. Yes, it doesn't get used much in my convertible with the roof down, but in inclement weather with the roof up it's a great boon in keeping the cabin warm and dry with no condensation
- Not using the aircon regularly (if not all the time) is false economy. I've had my car re-gassed every few years through lack of use of the aircon. Now it's just been done, the aircon switch is staying permanently on from now on!
- One day (maybe!) your car will be sold. An XJS with non-working aircon in the UK is immediately worth considerably less. People will price in the unknown to get it working and have to allow £500+
So, with your new rad and all the good work you've done, I'd get the aircon done properly as well. Turn the switch on, leave it there and the GF can have all the dry warm or cool air she likes!
As I said, I'll butt out now. Good luck with whatever you decide.
Paul
Old Aug 9, 2014 | 09:15 AM
  #103
Daim's Avatar
Originally Posted by o1xjr
It is amazing what you can achieve with a spray can if you put you left index finger in your ear and stand on your right foot only with you tongue in the correct position of course,then spray with one eye shut.
I do worse jobs with a spray gun.
Not sure how to take this...
I meant MY post as in "spray cans can get awesome results too... No need to leave a former painted part unpainted/base coated"
Otherwise: I don't know if I should be recognizing sarcasm, hidden "snot" or something else...
Old Aug 9, 2014 | 09:18 AM
  #104
Greg in France's Avatar
Very sensible post Paul. I would only add that (if the aircon is removed) as long as the thing is left so that the new aircon bits bolt/screw straight back into the car pipe system, it is an easy job to reinstall. As OB's system will be utterly shot after 14 years (pipes/compressor shaft seal/dryer and condenser) they will all have to be renewed anyway, so OB can wait until he wants or needs to do it.
You are 100% right about the compressor etc etc, if they are not used the shaft seal dries out and it's 'Goodbye Charlie' (Spats Columbo anyone?)
Greg
Old Aug 9, 2014 | 09:20 AM
  #105
Don't forget the link to that special rattle can stuff daim, please.
greg
Old Aug 9, 2014 | 09:29 AM
  #106
Daim's Avatar
greg
Thanks for the reminder Greg!
Spray Max - 2K Klarlack Spray (400ml): Amazon.de: Auto Spray Max - 2K Klarlack Spray (400ml): Amazon.de: Auto
Just an Amazonlink
Old Aug 9, 2014 | 12:00 PM
  #107
I think that's what Clarke meant also.
Old Aug 9, 2014 | 12:19 PM
  #108
orangeblossom's Avatar
And do you know what, you were right, 'Spray Can Stuff' is a great inclusion!
Old Aug 9, 2014 | 04:07 PM
  #109
Originally Posted by ptjs1
OB,
Paul
Hi Paul
Don't 'Butt Out' or go anywhere!
Your input is Invaluable! and I'm always learning new things.
For instance what I wasn't getting, that I suddenly got just now, was that Air Con wasn't Cold Air, it was 'Dry Air!'
Like one of those 'Air Conditioners' that they use for drying out buildings!
So I won't be doing anything rash, like chopping all the pipes out!
There is always a 'Dicky Bird in Hells Chance' that the thing might actually work but in any event that Rad could act as a 'Bitch Shield' to protect the Main Rad against any flying stones.
The most important thing at the mo, is to get her running and while I'm not going down the 'Concourse' route, I'm taking my time and trying to make as nicer job of her as my skills will allow.
So don't be afraid of jumping in, if you think that I'm doing it wrong, as that's what Forums are all about, especially an amazing one like this!
Old Aug 9, 2014 | 05:42 PM
  #110
o1xjr's Avatar
I meant the same thing, I have had some great looking paint jobs from spray cans.
Lots of prep and I use mixed 2 pack cans with the button on the bottom of the can you push to mix the two components of the paint.
My paint jobs with a spay gun turn out pretty horrid.
Old Aug 10, 2014 | 06:26 AM
  #111
Daim's Avatar
Ah! Okay! Now that is better As written, I was a tad unsure...
But yeah, I know what you mean with spray gun vs. rattle can...
Old Aug 11, 2014 | 11:39 AM
  #112
Default Thunder And Lightning Is Frightning But Nothings Gonna Stop Me Now!
While adverse Weather Conditions are doing there best to slow me down, Thunder/Lightning/Rain and Gale Force Winds, I'm still making progress.
As the Fan Shroud looked a 'bit rusty' make that Very Rusty! I decided it was best to take it out and found it looked a whole lot worse than it actually was.
All the metal was solid as confirmed when I gave it a good Shot Blast, followed by a Coat of high build Primer.
This will then be followed by a Coat of Black Hammer Paint but only when the Primer has thoroughly dried out.
Although it was a little bit of a struggle to get out, as I did not remove the Yellow Fan.
This was nothing to the job of removing the Header Tank, which was on the Nearside of the Engine Compartment.(UK)
It was just so Red with Rust that I felt it best to take it out, so I could have a proper look at it.
It may clean up or else may need replacing, so I'll give it a Shot Blast and see how it looks after that.
But in any event, I will have to replace all the Hoses @'Greg in France'
It's only held in place with 3 bolts. (2) captive ones at the front and (1) nut and bolt at the rear, all of which are bolted through the Wing of the nearside Front Wheel Arch.(UK)
All (3) Nuts were so solid, that they could not be undone, without the risk of breaking off the Captives, so I soaked them in a mixture of 50% Acetone 50% ATF @'Greg in France'
After 3 days and nights of Soaking in this, they finally came undone, at which point I was able to remove it, after the slightly easier job of removing the hoses.
As you can see from the photos, the paint was not only peeling off but the overall condition, doesn't look that great.
So I will make a decision, on whether or not to replace it when its cleaned up, the only good news being that I've still got a spare on my Scrap Car, which may turn out to be either better or worse.
Old Aug 11, 2014 | 12:53 PM
  #113
Daim's Avatar
Mine doesn't look much different. I won't be removing mine, as I know it all works... Luckily. But I have a second one I'll be sandblasting and powdercoating. Should keep clean for ever then
Old Aug 11, 2014 | 03:08 PM
  #114
Hi Daim
This one still probably works OK as it was still full of Anti Freeze and Water but if it starts to leak when I'm driving, then it could be 'Curtains!'
So I'd rather get it checked out now than later.
Old Aug 12, 2014 | 05:27 AM
  #115
Daim's Avatar
I was talking about the fan surrounding
Waterbottle I just renewed... Though it had loads of muck in the bottom.
Old Aug 12, 2014 | 11:19 AM
  #116
ronbros's Avatar
pic of my coolant tank;
80s VW part mounted as high as possible, bubbles rise to top, with 15 psi cap.
works great and have had no problems with bleeding and air pockets,20yrs.
Attached Thumbnails Cherry Blossom - Restoration 1990 XJS V12-jag-strut-brace-mom-ridin-shot-gun-v12-exhuast-mani-001.jpg   Cherry Blossom - Restoration 1990 XJS V12-hood-seal-chrome-001.jpg
Old Aug 12, 2014 | 11:48 AM
  #117
Never mind the Coolant Tank! I just want that Engine, it looks Epic!
Any more pics?
Old Aug 15, 2014 | 02:48 AM
  #118
Default Radiator Top Closing Panel before and after painting
The Radiator Top Closing Panel was so rusty that I thought I may have to replace it.
After a Shot Blast and Repaint it looked at lot better, so I couldn't resist trial fitting it before I took the next photo.
But one of the studs that holds the dryer will have to be replaced.
Check out the Front Beam that holds the Main Rad, even after 24 years it still almost looks like new.
Also the Camera doesn't lie and shows up every little bit of rust! so some work to do on those pulleys and adjusters, before I replace all the belts.
She's very gradually starting to come together.
Old Aug 15, 2014 | 04:49 AM
  #119
Terrific job on the cross panel OB. Congratulations. I am glad it is all coming together. The belts will not take too long, just soak all the adjusters with some mixture for a day or two before. The car lokks great and the cross member underneath the rad is amazing.
Greg
Old Aug 15, 2014 | 05:58 AM
  #120
Daim's Avatar
Bit by bit, step by step... I know how you feel when something looks great in the end or better than thought. As I removed my Jags waterbottle I was expecting to find a rust hole and loads of rot... Not a bit! Luckily my Jag hab been leaking oil from day one as it seems, as the engine bay has not rust anywhere. Wiped with a cloth: brand new paint beneath
Keep the good work up!
