Crankshaft Damper XJS V 6.0 1994
Old Oct 31, 2013 | 12:02 PM
xjsv12's Avatar
Default Crankshaft Damper XJS V 6.0 1994
I am looking for:
Crankshaft Damper XJ12 V 6.0 1994
EBC9389
New or used
Can you help with that?
Old Nov 1, 2013 | 06:46 AM
Keith's Avatar
No longer available new, and what's available used is probably as bad or worse than what you have. Better to have it rebuilt. I found a place that did a great rebuild, for a little over $100.00. Contact me if you want the source. Keith
Old Nov 1, 2013 | 12:30 PM
xjsv12's Avatar
Thank you. But my damper is not posible to rebuilt. destroyed
Old Nov 1, 2013 | 01:15 PM
JTsmks's Avatar
One's come up on e-bay...won't be cheap to ship but then again probably not a lot of choices.
Genuine Jaguar XJR s V12 6 Litre Pulley Pully XJRS Crank Shaft Damper | eBay
Old Nov 1, 2013 | 01:27 PM
Keith's Avatar
If it's just the rubber in between, it is rebuild able. If the metal parts are bent, then maybe not. The rebuild process replaces the rubber.
Old Nov 1, 2013 | 02:54 PM
warrjon's Avatar
The 94 will have a serpentine belt not a V pulley.
Try Rob Beere
Rob Beere-Engine Components
Old Nov 2, 2013 | 05:28 AM
baxtor's Avatar
EBAY listing won't suit marelli.
Old Nov 2, 2013 | 06:28 AM
warrjon's Avatar
a 5.3 damper wont fit a 6.0L crank the damper mount is totally different.
Old Nov 2, 2013 | 07:10 AM
baxtor's Avatar
I have a 5.3 damper on a 6.0. Fits fine.
Old Nov 2, 2013 | 04:48 PM
warrjon's Avatar
Well you learn something every day. As the dampers are totally different mount I was told they were not compatible. The 6.0 did away with the collet type fitting.
Old Nov 3, 2013 | 02:57 AM
baxtor's Avatar
You are correct regarding the collet being omitted Warren but the internal dimensions end up the same. That part of the crank is identical on both and I did check and then checked again. I have noticed some parts supplies note the dampers are not interchangable, don't know why cause it does fit.
Old Nov 4, 2013 | 10:45 AM
xjsv12's Avatar
No way. Not Marelli. For cone. it is from ebay
Old Nov 14, 2013 | 01:39 PM
Japthug's Avatar
i once bought rebuilt one from jaguar heaven in california. the manager is a good guy and will help you.
Old Nov 24, 2013 | 06:41 AM
xjsv12's Avatar
Who is he? Link please.
Old Nov 24, 2013 | 08:02 AM
kenatofc's Avatar
I have a 89 xjs 5.3 that I bought for parts for my 89 xjs. I will be getting to breaking this car down after I rebuild the rear calipers in mine after turkey day... I am willing to provide parts at reasonable prices plus actual shipping prices to all on the forum.... It will probably be after the first of the year. AFIK, everything was working. If something is not, I will refund all but shipping.... Interior pretty well shot in the parts car. body is in good shape, good glass, etc. Just let me know !!
Ken in Wild and Wonderful West Virginia (By Golly)...
Old Nov 25, 2013 | 03:46 AM
Japthug's Avatar
Just google "Jaguar Heaven" and you can hit the link on the top of the page.
Old Nov 27, 2013 | 02:43 AM
xjsv12's Avatar
To kenatofc
5.3 is not for my engine.
Old Jan 11, 2019 | 03:46 PM
mark scott's Avatar
New or used
Old Jan 12, 2019 | 07:36 AM
xjsv12's Avatar
That was five years ago. I was on a jaguar parts day in the UK and bought two there.
Old Jan 19, 2019 | 11:02 AM
mghirsch's Avatar
There are places the rebuild the damper. You can google them.
