Dash Bulbs
Old Mar 16, 2025 | 11:35 AM
JaguarDon's Avatar
Default Dash Bulbs
I hava a 1989 Xjs V12, I need to replace my warning light bulbs. I would like to use 5 watt standard bubs and not LED due ti heat factor, Does anyone know where U can order these. Also, are the bulbs in the speedo and tach the same size bulbs, Thanks
Old Mar 16, 2025 | 01:20 PM
Greg in France's Avatar
Don
I replied to this a couple of days ago. Trying again:
Amazon Amazon
If this link disappears, search for 5 watt push fits on amazon.
Old Mar 16, 2025 | 03:45 PM
JaguarDon's Avatar
Default Dash Bulbs
Thanks fir quick reply Greg, Shourd I get the T3 or T5 size, Aso, Are the speed and tach same size, Thanks
Old Mar 17, 2025 | 01:07 AM
All the same sise. T5s for sure. The hopeless OEM ones are T3.
Note that inside the white part of the cluster, into which the bulbs poke from their holders, there is a green filter. This discolours and if it has, needs to be removed. To get at it you need to unscrew the white part of the plastic from the black part. It is a good plan to do this anyway, in my view.
There are some pics and writeup on here from me that I will try to find!
Old Mar 17, 2025 | 03:24 AM
Cannot find my thread/posts, but here are some photos
Cluster white part off the black front part reveals the green filters
Green fiters off the cluster, these were, in fact, not darkened.
Some of the green filter locations, you can jusr see the small rivet holes that hold them on each side of the bulb hole
Old Mar 18, 2025 | 11:40 PM
BuckleSpring's Avatar
What "heat factor" are you referring to? If anything, the LEDs should be significantly cooler than the incandescent bulbs. I replaced my cluster bulbs w/ LED's probably over 2 years ago and they've been fine (just keep the alternator/battery bulb incandescent or else you can get charging system problems or the LED will just always be on w/ a slight glow)
razorboy
Mar 4, 2025 02:46 AM
JessN16
May 12, 2016 11:37 PM
rgp
Mar 13, 2014 05:07 AM
jkjag
Feb 11, 2011 09:59 AM
