Dead battery. Locked trunk. Can't enter
Old Jun 21, 2008 | 09:36 PM
mghirsch's Avatar
Default RE: Dead battery. Locked trunk. Can't enter
You should be able to getg into the trunk with the key. Try having the key straight up and down and then opening the trunk.
If the lighter idea doesn't work, under the hood, on the firewall, are a couple of terminls that feed directly to the battery.
Old Jul 5, 2009 | 06:24 PM
Doug's Avatar
Originally Posted by Vanjagman2009
I winterized the car, a 94 XJS V12 Conv. - disconnected the battery - then by mistake used the valet key. Now the trunk won't open. I tried supplying power via the lighter socket but that only seemed to supply power to some of the systems, indicators, windows. No power to the horn, radio, seats etc. And of course no power to the central locking.
I've looked under the hood but can't see an obvious terminal to attach the positive jumper lead to. Can anyone be more specific? Or tell me which is the hot pole on the alternator.
Grateful for any help anyone has.
Not sure about a '94 model but the older XJSs had two "+" posts on the firewall
Old Sep 1, 2011 | 10:44 AM
samc's Avatar
Default Dead battery, locked trunk
Thanks to this forum, I was able to unlock my trunk. The key wouldn't work at first, but the WD40 in the key hole did the trick. You just have to make sure the spray gets past the shield of the lock. Luckily, my spray can had the staw-like attachment that could get past the shield.
Happy driving!
Old Sep 1, 2011 | 03:11 PM
jeffn's Avatar
Goods news, one less thing like Forrest Gump said..
Old May 7, 2016 | 10:40 AM
HypnoGuru's Avatar
Happy driving!
Thanks to SAMC, I got my boot open. A little WD-40 and slight pressure on the handle while jiggling the key worked for me. No need to hotwire the lighter, battery on charger as I write this.
Old May 13, 2016 | 02:10 PM
Jonathan-W's Avatar
You can open the engine cover and disconnect the high low beam dip module, locate the BROWN wire in the socket that it plugs into and plug a spade connector into it and charge the battery that way....
yes that brown wire is normally HOT...
how do I know? my high low beam module went out and I had to analyze it and make a way to get home with the low beams hot wired on....
5 days later my new high/low beam module arrived....
99xk8guy
May 28, 2024 09:36 PM
BadKat174
May 26, 2023 12:29 AM
ferraripete
Sep 12, 2016 09:02 AM
XJsc-guy
Nov 23, 2015 01:56 PM
smith356
Oct 7, 2015 06:41 PM
