Is Deionised Water the Same as Distilled Water?
Old Oct 23, 2016 | 06:20 AM
orangeblossom's Avatar
Default Is Deionised Water the Same as Distilled Water?
Hi I think I've found the right Water to put in my Radiator but just need to check XJS V12
This is deionised Water
Would this be ok?
Old Oct 23, 2016 | 06:34 AM
paydase's Avatar
Yes, basically the same.
Distilled or purified (through resins) is aiming at removing salts that are constitued by ions (anions and cations).
There is always some left, but negligible to favour electrical conduction (and at the very end H+ and OH-, but at concentrations of 10 to the minus 7)
Old Oct 23, 2016 | 08:56 AM
Ahhhhhh Yes!
I couldn't have put it better myself (Lol)
Thanks for your help I'll get some.
Old Oct 24, 2016 | 03:02 AM
ptjs1's Avatar
Hi OB,
Just to clarify, are you talking about water for your cooling system or your battery?
For my cooling systems, I admit that I just tend to use a 50-60% concentrate of anti-freeze and mix that with filtered tap water. By using a good anti-corrosion mix and filtered water with much of the limescale removed, and knowing that I'll be changing the coolant within a few years, I think that's quite acceptable.
Paul
Old Oct 24, 2016 | 04:42 AM
Originally Posted by ptjs1
Hi OB,
Paul
Hi Paul
The Water down my way is so Hard that every time you turn on the Tap a voice says 'What You Lookin at!'
So I've ordered 25L of De-Ionised water, which was only £10 so when mixed 50/50 I will have plenty to do all my Jags as well as the Merc.
Old Oct 24, 2016 | 05:53 AM
AND make that whiskey.
Old Oct 24, 2016 | 06:44 AM
user 652867429824's Avatar
and were I live we have plenty of corn to make the whiskey
Old Oct 24, 2016 | 05:28 PM
Jonathan-W's Avatar
better!
Old Oct 24, 2016 | 05:47 PM
ronbros's Avatar
YUP, i drove across IOWA, all day long , nothing but corn!
Old Oct 25, 2016 | 03:47 AM
Steve M's Avatar
Was it as high as an elephant's eye?
Old Oct 25, 2016 | 03:53 AM
Greg in France's Avatar
Wasn't that Oklahoma! ?
Greg
Old Oct 25, 2016 | 07:14 AM
Steve M's Avatar
I think that the elephants migrated.
The corn kept getting in their eyes.
Old Oct 25, 2016 | 11:44 PM
afterburner1's Avatar
Those jokes are so corny!
Old Oct 26, 2016 | 12:01 AM
I have a theory about engine coolant. Here in Houston we don't worry to much about freezing but we do about overheating. I keep a 50/50 mixture of quality antifreeze and city water in the coolant system. I do two checks: one for freezing temperature and one for PH. So far each test maintain a constant value. I do not change coolant but do supplement with a conditioner I.E. rust and corrosion inhibitor. So far no overheating even with A/C and no signs of deterioration.
