Door Adjustment, glass adjustment etc
Old Mar 23, 2015 | 11:06 PM
Spikepaga's Avatar
Default Door Adjustment, glass adjustment etc
Hello guys,
My car is going in to have the entire sides re sprayed (probably stripped to bare metal) due to problems with bubbling etc from the last paint job. Hopefully this time I will be satisfied with the work, and I wanted to get some things done "right" while its at the shop:
1-I want the doors adjusted properly so they are flush when shut. What do I need to do?
2-the door glass seems to have been improperly installed after the previous paint job. It seems like it goes up and down in a incorrect way. How do I get it back to factory specifications?
3-the outside passenger side door handle does not want to return to its normal position easily on its own. How do I get it back to normal?
4-When I wash the car it gets wet on the inside. What seals do I need to replace?
5-when they lifted the convertible top to paint last time it seems like it was not the same along the bottom seam. Is it a cable that needs to be replaced?
Any help would be greatly appreciated!
Old Mar 24, 2015 | 02:49 AM
Greg in France's Avatar
Spike
I cannot help with the glass, but the door adjusts as follows:
Loosen hinge nuts in A pillar (in a large access holes behind the shin level trim)
Loosen hinge bolts in door (door trim off)
Trial and error (tilting in/out; shunting in/out; raising lowering until it is right. using a jack under the door helps with someone helping you!
If the door shut on the B pillar is a bit proud, or a bit misaligned up and down, but otherwise OK from the tilt point of view, loosen the torx screws a touch and move the B pillar locking bit up and down and in and out as required.
If all is well but the front edge/wing is not quite right, then the wing top has to be loosened on its bolts along the gutter and (hard to get at) ones in the gap under the A pillar and it can be aligned quite easily with the door leading edge.
Greg
Old Mar 24, 2015 | 06:42 PM
sidescrollin's Avatar
sometimes the regulator can be adjusted a little to let it go up more naturally, but generally the issue with windows going up is with the seals inside the track being worn away and not properly supporting the window to let it track correctly
Old Mar 25, 2015 | 02:30 PM
Spikepaga's Avatar
Spike
Greg
Thanks very much Greg. That solves the door alignment problem
Old Mar 25, 2015 | 02:32 PM
Spikepaga's Avatar
Thanks!
So do I need to buy new tracks or refurbish them??
Thanks!!
Old Mar 29, 2015 | 07:49 AM
ptjs1's Avatar
Spikegaga,
The old "XJS Supplementary Information" CDROM contains a few sections on water leaks in a Convertible and how to seal them. It also contains a section on how to adjust the front and rear windows for fore / aft and lateral movements. You could (happily!) spend a weekend going through the various water sealing and glass adjustment procedures.
The old CDROM is Jaguar part number JHM1123. You can still buy this from Jaguar Heritage shop here: Jaguar Heritage. Technical Publication DVDs
I also understand that the content of this CDROM is now contained within the new overall Jaguar XJS DVD also available from Jaguar Heritage.
Hope that helps
Paul
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Nov 10, 2015 11:05 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
mrsimpson
Sep 15, 2015 01:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
