Dual electric fans
Old Mar 25, 2014 | 03:39 PM
dickc's Avatar
Smile Dual electric fans
I'm thinking of going to dual fans on my 89 XJS, any helpful hints? Where is the best source for these?
Thanks,
DickC
Old Mar 25, 2014 | 05:38 PM
Katoh's Avatar
Depending on where you are, here in Aus, the Ford AU falcon is nearly identical to the xjs in size, this is what I have read. Sorry can not think of who had this information came from at the moment but I did look into it. You can buy a complete unit with cowl and fans for around $100 on Ebay, I was just given one from a friend. I wont install mine till I do the Motor\gearbox transplant.
Old Mar 25, 2014 | 06:21 PM
dickc's Avatar
I'll try Ebay, thanks.
DickC
Old Mar 25, 2014 | 08:47 PM
Doug's Avatar
I've often wondered if the dual fan assembly from an X300/XJ6 would work?
Jaguar 1995 to 1997 XJ6 Radiator Cooling Fan Assembly MNC4270AC | eBay
Old Mar 26, 2014 | 06:55 AM
Katoh's Avatar
Here is the site I got the intial information from, funny when things come flooding back to you. Lots of good information here.
Enjoy!
XJ-SC Modifications
Old Mar 26, 2014 | 11:12 AM
dickc's Avatar
Thanks,
DickC
That diagonal mounting would be tricky for me.
I found this site with fans and kits: v12s Jaguar XJS V12 Aluminum Electric Cooling Fan Systems
May be a little pricey but may be worth it.
Thanks Doug,
Dick C.
Old Mar 26, 2014 | 11:13 AM
dickc's Avatar
Enjoy!
XJ-SC Modifications
Thanks Katoh!
Old Mar 27, 2014 | 09:01 AM
Japthug's Avatar
Hi Doug, the X300 fan shroud is too square for an XJS, so it needs to be cut down and remade to fit in the XJS's engine compartment. My acquaintance mechanic did the job, but he said it was totally a hard job to do.
Fan's power is much enough to cover the V12's heat though. So if remaking the shroud is not a problem it could be a good option.
Old Mar 27, 2014 | 09:58 AM
calvindoesntknow's Avatar
I bought a fan kit and it's well worth the money you spend on it. It was basicly drop in fit
Old Mar 27, 2014 | 10:25 AM
dickc's Avatar
Thanks japthug, I figured as much, if a mechanic said it was hard then definitely to much for me!
Thanx,
DickC
Old Mar 27, 2014 | 10:27 AM
dickc's Avatar
Which kit did you get?? I'm going to go with the kit.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Collector1
Sep 28, 2015 03:52 AM
Darrenmb
Sep 27, 2015 08:43 AM
1100me
Sep 7, 2015 06:26 AM
