Exhaust manifolds weld
Old Sep 4, 2018 | 02:58 PM
Keesh's Avatar
Default Exhaust manifolds weld
Let the exhaust manifolds weld today. Done with metal active gas (MAG) welding with Sagox K15 gas.
Old Sep 4, 2018 | 03:19 PM
sidescrollin's Avatar
How did you heat it during the process?
Old Sep 4, 2018 | 03:48 PM
Keesh's Avatar
The repair with MAG welding can be made without preheating.
Old Sep 4, 2018 | 03:58 PM
Jagboi64's Avatar
Interesting. Usually cast iron has to be preheated and welded with a high nickel content filler wire.
Old Sep 4, 2018 | 04:06 PM
Keesh's Avatar
Use Crown Alloys 44-30 cast iron wire ( Nickel-Iron-Manganese)
Old Sep 4, 2018 | 06:40 PM
Jagsandmgs's Avatar
You’re going to have to do mine next. Only thing wrong with the AJ16.... well that and a CPS with every oil change.
Old Sep 4, 2018 | 07:10 PM
Keesh's Avatar
I have thirteen years a X300 4.0 with a AJ16 engine and never had a problem with the CPS.
Old Sep 4, 2018 | 09:07 PM
Ezrider's Avatar
proper weld prep goes a long ways in cast iron repairs. i not that familiar mag welding but iv mig as well as stick welded cast iron with using proper weld prep stop drilling the crack and v-ing the crack all the way out pre heat peeing the weld and slow cool down.
the tie ins don't look that great on those welds and without pre heat, id be slightly concerned cracks will re-appear next to the old repair. but if it does just gives you a chance to practice again.
Old Sep 5, 2018 | 02:22 AM
Keesh's Avatar
Five years ago I welded the exhaust manifolds of my X300 with MIG welding the same way and those are still not cracked. With the X300 I drive sporty and on German motorways at speeds up to 200km/hour.
Old Sep 5, 2018 | 08:07 AM
brinny's Avatar
Well done mate mate and thanks for sharing.
SuperRoo
XJ40 ( XJ81 )
Jul 24, 2013 05:17 AM
SafaJag
Mar 8, 2013 02:34 PM
osyris
Dec 25, 2012 07:17 PM
Mr. Fox
Jan 11, 2011 08:23 PM
Bacardi 151
Sep 14, 2007 07:48 PM
