Fluctuating Oil Pressure Reading -
Old Sep 18, 2024 | 03:32 AM
CharlesHK's Avatar
Default Fluctuating Oil Pressure Reading -
Greetings everyone,
My 1992 XJS 5.3L oil pressure gauge is fluctuating when I drive now. Checked oil level and it is fine; no oil leak.
I had a similar problem with my 1993 Daimler Double Six 6.0L and replaced the old unit with one that never fluctuates, but goes to the mid point of the gauge. Since replacement, its never been a problem.
Is there such a "fix" for the XJS?
Or, do I just replace C46272 with an aftermarket model? (I doubt the original has ever been replaced)
Is there another oil switch that people would recommend to be changed at the same time? If so, please provide the part number.
Many thanks,
Charles
Old Sep 18, 2024 | 05:27 AM
ptjs1's Avatar
Charles,
Jaguar brought out a new sender unit in the 90s, apparently because US owners complained that the pressure gauge fluctuated (as indeed it should at times!). The new sender unit acts really as an on/off switch. If you’ve got any real pressure, the gauge just sits in the middle. It’s not ideal for those of us who really want to know an accurate pressure reading, but it obviously kept the bulk of customers happy (and ignorant of the real pressure!).
AFAIK, the part number remained the same. I still have the original on my 4.0 AJ16 and although the gauges are never that accurate, I'm quite happy seeing it go up and down depending on temperature and revs.
Paul
Old Sep 18, 2024 | 09:44 AM
jal1234's Avatar
Originally Posted by CharlesHK
Greetings everyone,
Many thanks,
Charles
It's entirely normal for the gauge to fluctuate. It'll be fairly high when the engine is cold. Once warmed up, the idle pressure will be low, and increase as engine RPM increases. Just note what is normal. As was stated, some dealers just installed a switch, so the gauge read mid-range if there was any pressure at all. That'll give you no indication of what the real oil pressure is.
Jon
Old Sep 18, 2024 | 10:20 AM
MooseOHJ's Avatar
Are you saying it fluctuates as you hold a speed and rpm on the highway? Like you're cruising at 2000 RPM and the oil psi indicator is going up and down? Or do you mean when you start it it is one reading, once it's warm its another, and then idle vs at speed is different?
Old Sep 18, 2024 | 10:32 AM
jal1234's Avatar
Once warm, at a given constant rpm, oul pressure should be constant. It will fluctuate with RPM. It will lag a bit as RPM changes, that is, the change in pressure won't be instant.
Jon
Old Sep 18, 2024 | 11:40 AM
CharlesHK's Avatar
Greetings. It fluctuates while holding speed, and at idle. It's all over the place.
Old Sep 18, 2024 | 12:17 PM
jal1234's Avatar
In that case, I'd suspect a loose connector, frayed wire, or a bad connection at the gauge. Bad senders normally don't do that.
Old Sep 18, 2024 | 01:02 PM
MooseOHJ's Avatar
I would agree. Does the gauge completely bottom out or top out?
Old Sep 18, 2024 | 01:21 PM
motorcarman's Avatar
Things we got when I worked at the dealer.
File Type: pdf
Old Sep 18, 2024 | 01:44 PM
jal1234's Avatar
I think he's suffering a different issue. Oil viscosity should not cause the gauge to fluctuate at a constant RPM.
Jon
Old Sep 18, 2024 | 02:19 PM
Greg in France's Avatar
Change the sender, check the wire for continuity.
Wyzawazza
Apr 24, 2024 05:38 PM
jomo
Jul 17, 2015 07:11 PM
XJ6 Continental
General Tech Help
Sep 23, 2012 01:42 PM
rolexmike
XJ40 ( XJ81 )
Feb 28, 2011 08:59 AM
JagNewbie
XJ40 ( XJ81 )
Aug 14, 2009 11:22 AM
