Help - brake booster valve?
Old Nov 21, 2021 | 10:53 AM
MrAndersonGCC's Avatar
Default Help - brake booster valve?
1983 XJS. Sorry if my terminology is poor, but last night I was trying to remove the vacuum line that runs to the top of the brake booster (aka servo) when the plastic adapter/plug/valve thing broke:
Is this something I can replace on its own or will I need to purchase a new servo?
I found this, wondering if it would work: Brake check valve
Old Nov 21, 2021 | 03:36 PM
rgp's Avatar
rgp
[QUOTE=MrAndersonGCC;2467457]1983 XJS. Sorry if my terminology is poor, but last night I was trying to remove the vacuum line that runs to the top of the brake booster (aka servo) when the plastic adapter/plug/valve thing broke:
At the price it's worth a punt, probably a grommet might go down well
Old Nov 21, 2021 | 04:19 PM
Here’s where I’m at. Either super glue the old plastic piece back together or attempt to use the Dorman one I picked up today. Will probably just order another jag one but in the meantime need to have something to move the car short distances. Video below.
Old Nov 22, 2021 | 08:55 PM
Doug's Avatar
I'm pretty sure you'll find that the plastic elbow (RTC1128) is nothing more than a....plastic elbow. And not a check valve.
The check valve (CAC4188) is in the plumbing of the vacuum pipes and hoses.
Old Nov 22, 2021 | 08:58 PM
Yes, thanks for clearing that up Doug. I'll be making a trip to the auto parts store tomorrow to find something that will fit.
Old Nov 22, 2021 | 08:59 PM
Doug's Avatar
By the way, all the Jaguar versions I've seen were red and had a single nipple. I think the one you have is a replacement intended for some other application or perhaps a "universal" replacement
Old Nov 22, 2021 | 09:12 PM
Yeah I suspected as much. I noticed in your picture what looks like a bag of grease; is greasing the plastic elbow recommended? (Talking about the side that goes into the servo, not the vacuum line side).
Old Nov 23, 2021 | 12:01 AM
Doug's Avatar
Silicone grease, I suspect.
The original elbows, in my experience, are a very tight fit. The grease helps things along a bit
cat_as_trophy
Jun 3, 2021 06:49 AM
yachtmanbuttson
Sep 12, 2019 07:43 PM
CaleyThistle
Apr 6, 2018 04:42 PM
Lcgi
Apr 14, 2016 02:59 PM
denraden1
May 9, 2013 08:11 AM
