how to remove quarter windows/trim
Old Feb 23, 2012 | 12:16 PM
calvindoesntknow's Avatar
Default how to remove quarter windows/trim
how do you remove the quarter windows and the trim underneith as well as the trim on the doors by the windows? im tearing down to do a full repaint
Old Feb 24, 2012 | 04:54 AM
Greg in France's Avatar
Calvin
You pull back the chrome collar on the front end of the door armrest and undo the lage pozi headed bolt you find underneath. You unscrew the courtesy light chrome plate from the front inner edge of the door. You undo a chrome screw you will find on the bottom inner edge of the door card by the oddments bin on the card.
Then carefully prise all round the door card from top front, along the bottom, and up the rear edge, popping out the pop fixings. Then, holding the card by the armrest, jerk it upwards sharply, which disengages the card from the door top, and also the metal piece fixed on the inside of the card by the armrest, which hooks over the metalwork of the door centrally.
When putting it back, if you do not get this central piece properly engaged, the door card will not be solidly fixed and will 'give' when you pull the door closed.
Greg
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
picard
Sep 19, 2015 08:13 PM
jmfan
Sep 12, 2015 10:28 PM
