ID Wheels
Old Nov 5, 2021 | 10:37 AM
MrAndersonGCC's Avatar
Default ID Wheels
Anyone know what wheels these are? They almost look like painted stock wheels, but they're clearly bigger (16" or 17" is my guess), and wider, at least in the rear. Really like the look of these.
Old Nov 5, 2021 | 10:57 AM
Jagboi64's Avatar
They look like 1995-97 XJR wheels that have been painted black.
Old Nov 5, 2021 | 11:27 AM
Noah's Avatar
I agree, those are 95-97 XJR wheels that have been painted. 17" x 8" with 33mm offset. I'm not aware of them making different widths for the rear. Great looking wheels imo on an XJS, XJ40, X300, etc.
Old Nov 5, 2021 | 11:33 AM
It certainly looks like you guys are right; anyone know how these fit up to an XJS? The specs on the XJR Supercharged wheels are: 8Jx17 ET33 with a 255/45 tire. And more than just fitting in the wheel wells - I'd want to make sure there isn't too much stress on the wheel bearings.
Based on this calculator comparing the stock 83 XJS wheels/tires vs. the XJR's, weight distribution should stay centered:
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Old Nov 5, 2021 | 11:39 AM
Nevermind, looks like I found the answer on this forum: https://www.jaguarforums.com/forum/x...-wheels-65576/
"...So the late-90s 17" X 8" XJR wheels, with this "magic" offset and identical bolt pattern and hub bore are the easiest way to upgrade to a 17" X 8" wheel on the XJ-S."
Old Nov 5, 2021 | 06:46 PM
Jagboi64's Avatar
Just be aware that 17" wheels can cause tramlining in a way that 15" and 16" won't. At one time I had a 1995 VDP with 16" wheels and a 1995 XJR with those 17" wheels and the VDP would drive much straighter and easier than the XJR. The XJR felt like it was twitchy and nervous, the VDP wafted along on the same piece of road.
Old Nov 6, 2021 | 08:58 PM
Xjeffs's Avatar
Default XJR sport rims
Yes those are 95-97 XJR "Sport" rims. I found a painted pair and stripped them and they are great on an XJS.
Old Nov 6, 2021 | 09:33 PM
Nice! 255 tires all the way around of just in back? Lowered at all?
Old Nov 7, 2021 | 02:45 AM
Xjeffs's Avatar
yes 255 ask the way around. Not lowered at all, no fender rubbing issues, no tram lining. .
steve_k_xk
Aug 29, 2017 07:31 PM
caunyd
Mar 13, 2016 07:36 PM
bmarshall1
Oct 10, 2014 08:50 AM
SeanPeterLynch
May 21, 2014 08:43 PM
