Idle finally @ 750
Old Jul 10, 2012 | 07:54 AM
mrtalkradio's Avatar
Default Idle finally @ 750
I have to use an * though. I did it with a very minor mod. It is evident my AAV isn't working correctly. I used very thin, high temp aluminum tape. I covered the hole within the air filter housing. You can within 2 minutes use a pin to increase idle speed if needed in the cooler weather. I'll work on that AAV in the fall. It is a different car @ 750 idle for sure.
Old Jul 10, 2012 | 08:12 AM
Doug's Avatar
You'll want to disconnect the distributor vent hose where it attaches to the AAV hose or you'll end up at the side of the road with the innards of the distributor soaking wet with engine oil.
Ask me how I know.
Old Jul 10, 2012 | 11:09 AM
Originally Posted by Doug
Ask me how I know.
I'll do that immediately.
Old Jul 10, 2012 | 08:18 PM
Greg Edge's Avatar
Smile
Ask me how I know.
How do you know, Doug?
Old Jul 10, 2012 | 08:34 PM
Doug's Avatar
You're gonna make me CONFESS? How cruel!
I tried the same thing on a V12 once.....blocking off the inlet to AAV. And the end result was a distributor full of oil. Took a couple days. It wasn't my car either. I was trying to save a "I'm tight for money" guy $300 for a new AAV.
No good deed (or poorly conceived plan) goes unpunished :-)
I re-routed the distributor vent to the back side of the air filter housing. All's well since then.
Old Jul 10, 2012 | 08:36 PM
Greg Edge's Avatar
Part of my day job is to get the confession so we can resolve the concern. But anyway I was just poking fun.
Old Jul 10, 2012 | 09:02 PM
Doug's Avatar
Forgive me father, for I have sinned :-)
Old Jul 10, 2012 | 09:39 PM
Mish_Mish's Avatar
I should probably offer some sort of AAV rebuild service, since that nice French gent. had taught me how to use Volvo marine wax bulb in those...
P.S. mine idles at 450 rpm like a charm
Old Apr 23, 2014 | 05:54 PM
1800doogie's Avatar
Default Ebay aav rebuild
Just noticed a guy on E-bay offering to rebuild your aav for $70 us. Seller is my1 bugs. Send him yours, he rebuilds and ships back. Mines totally dead, and when I get the extra funds, Ill try it out! Parts are getting scares, expensive, if someone comes up with a service that helps us, Im gonna give them a go around!
Old Apr 24, 2014 | 09:14 AM
sidescrollin's Avatar
wtf does yours idle at 450 for??
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
carl purchase
Oct 14, 2015 06:14 PM
Pontsu
Oct 1, 2015 09:56 AM
Lord_Rowan
Oct 1, 2015 01:45 AM
