Idles too fast-1996 4.0
Old Sep 5, 2014 | 05:41 PM
RagJag's Avatar
Default Idles too fast-1996 4.0
My idle has increased from 600 to 750 RPM in drive. Is this an indication of a defective Throttle Position Sensor. These are over $400 on E-Bay. Do any of you know if this sensor causes this. My CPS and Idle Air valve are new. Amazing that the sensor for the 4.0 is so expensive as compared to other TPS on cars. Any advice would be helpful
RagJag
Old Sep 5, 2014 | 06:45 PM
ptjs1's Avatar
Ragjag,
My first thought would be to look for a carbon coating buildup on the throttle body which is keeping the butterfly slightly open thus raising the idle. Try cleaning it gently.
Next thought is an air leak somewhere on the inlet side. Go around with a spray and check every possible joint area whilst the engine is running.
Just to let you know, a new throttle potentiometer (JLM12074) from Jaguar is £141 so not sure why people would ask $400 on ebay.
Good luck
Paul
Old Sep 6, 2014 | 06:25 AM
jeffriescr's Avatar
RagJag
I just bought one from Jaguar classic parts (Heritage) last month, with exchange rate and shipping it came to $155.26
Craig.
Old Sep 6, 2014 | 06:56 AM
Japthug's Avatar
When the TPS dies the idle goes up to 1200-1500, so this is not the case.
+1 on Paul's post.
Old Sep 6, 2014 | 07:13 AM
Vee's Avatar
Vee
1. Clean throttle body
2. Perform a manual idle speed reset. (Check forum, I know the steps we're posted, I think I may have posted it!)
3. Take car to dealer to reset adaptations. should cost you $150.
One of those three steps should resolve your problem.
Old Sep 6, 2014 | 09:01 AM
RagJag's Avatar
Ptjs1, Several on E-Bay were $500-600.
RagJag
Old Sep 6, 2014 | 10:17 AM
ptjs1's Avatar
Ragjag,
I think that probably goes to show that there are people on ebay just trying it on. £141 new from Jaguar, so no excuse for people charging $500.
Good luck with sorting it.
Paul
Old Sep 6, 2014 | 11:21 AM
RagJag's Avatar
ptjs1, ordered the part from Heritage. Cost about $200 with the higher exchange rate.Still less than half the E-Bay prices. This may not be the problem but the one in there now is 18 years old.
RagJag
Old Sep 7, 2014 | 09:25 AM
RagJag's Avatar
Vee, there are no dealers in Richmond that work on the XJS. 14 years old is the cutoff.
RagJag
Old Sep 7, 2014 | 02:53 PM
Vee's Avatar
Vee
You may consider taking a ride up to Springfield, VA. There's a Jag shop with a working PDU!
RagJag
Old Sep 8, 2014 | 08:21 AM
RagJag's Avatar
Thanks, Vee. I will consider doing that if I can't solve the problem myself.
I have heard of that shop before.
RagJag
aode06
Jul 28, 2023 02:26 PM
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
