Jaguar XJS 3.6 1985 fuel problem?
Old Mar 17, 2018 | 07:51 AM
JigJag's Avatar
Greg,
Wouldn’t a failure in the ECU fuel pump activation circuit drop fuel pressure to 0 rapidly and shut the engine down?
Old Mar 17, 2018 | 08:40 AM
Greg in France's Avatar
Could well be; but this fault the OP has established is fuel; so I feel pinpointing it should now be pretty straightforward. It just occurred to me that it is a possibility that the pump electrical feed could be part of it. BUT, my money is on a blocking new main filter (had that on my Range Rover once and it took ages to find - I was young then!) or a collapsing feed tube to the pump.
Old Apr 5, 2018 | 03:47 AM
unclenry's Avatar
finally the engine is ok. the mechanic has cleaned the tubes number 13 and 19 of the scheme. this morning I traveled about 70 kilometers and I had no problem.thank you all for your cooperation
Old Apr 5, 2018 | 07:38 AM
Well done. If it happens again, rather than just cleaning them fit new ones.
Old Apr 6, 2018 | 07:38 AM
unclenry's Avatar
Do you know any retailer of these spare parts?
Old Apr 6, 2018 | 10:55 AM
Hose 19 is the important none, it is NOT a high pressure hose, so any good quality 1/2 inch (13mm) internal diameter fuel hose will do it.
Hose 13 (actually 11) is a breather hose, so if it is clear, probably not to worry. They are available though, part number CBC6346
Jaguar Partno_CBC6346_BREATHER HO_David Manners Group with Alts
and some on UK ebay too.
Executivekev
Feb 12, 2022 11:43 AM
camcor
Feb 15, 2014 11:27 AM
beamer
Oct 22, 2010 03:43 PM
Kbudd
Mar 8, 2010 12:41 PM
Kbudd
Mar 8, 2010 07:04 AM
