Jaguar XJS 3.6 1985 fuel problem?
Could well be; but this fault the OP has established is fuel; so I feel pinpointing it should now be pretty straightforward. It just occurred to me that it is a possibility that the pump electrical feed could be part of it. BUT, my money is on a blocking new main filter (had that on my Range Rover once and it took ages to find - I was young then!) or a collapsing feed tube to the pump.
finally the engine is ok. the mechanic has cleaned the tubes number 13 and 19 of the scheme. this morning I traveled about 70 kilometers and I had no problem.thank you all for your cooperation
Hose 19 is the important none, it is NOT a high pressure hose, so any good quality 1/2 inch (13mm) internal diameter fuel hose will do it.
Hose 13 (actually 11) is a breather hose, so if it is clear, probably not to worry. They are available though, part number CBC6346
Jaguar Partno_CBC6346_BREATHER HO_David Manners Group with Alts
and some on UK ebay too.
camcor
Feb 15, 2014 11:27 AM
