Left rear quarter window won't go up
Old Sep 7, 2023 | 04:01 PM
UDTDave's Avatar
Perfect! Thanks so much. That probably saved me $1,000.
Old Sep 7, 2023 | 04:07 PM
Vee's Avatar
Vee
Do not spend $1,000 to fix this.
Don't you dare.
Old Sep 7, 2023 | 04:16 PM
UDTDave's Avatar
Exactly! I won’t have to now. I’m pretty mechanically inclined but don’t know squat about car interiors.
Old Sep 8, 2023 | 11:07 AM
JayJagJay's Avatar
Sorry for the bad info Dave. My car is a bit older and different in areas fo sho... Good luck!
Old Sep 8, 2023 | 12:40 PM
WhiteGC's Avatar
Illustrations to Vee's description of the TWO tabs ...
Old Sep 22, 2023 | 02:20 PM
UDTDave's Avatar
Update! Thanks to some great advice I got the $6 tool kit off Amazon and the panel came off with no damage. After some messing around I got the motor out and once apart discovered one brush was damaged along with a big wear mark on the magnets. I got it working but it was intermittent.
Solution was buy a new motor from Terry’s Jaguar parts. Not the cheapest solution but the upgraded motor was delivered in just a few days and other than having to transfer the original plug it was a perfect fit.
thanks to everyone who participated.
Up next a new high side low pressure switch on the A/C that is leaking. Same scenario, the replacement switch has a different plug but looking forward to having A/C again here in Florida.
Old Jan 26, 2024 | 07:33 AM
gleudemann's Avatar
Default 96 xjs drivers side rear window won’t go down.
Originally Posted by skagitcom
My 75,000 mile 1994 XJS Convertible developed a intermittent at first, but now LR quarter window that won't go up. When the problem first started I could get it to go up by pulling on the window a few times before raising the top. Where to look? Is this a bad motor? It is stuck in the down position.
I keep reading on the forums that if you tap the motor with a 24” screw driver it will fix the problem. No where can I find how or where to access the motor. Is it at the window slot? How do you know if you are hitting the motor? The window is up… do you attack it from the inside or outside? Thanks in advance!
Old Jan 27, 2024 | 06:30 AM
  #28
ptjs1's Avatar
Either remove the vent trim panel in the B-post, or else fully remove the interior rear quarter panel. Some of the threads which discuss this topic will have pictures and the procedures. A quick search will give you the answers.
Good luck!
Paul
Old Jan 27, 2024 | 08:01 AM
gleudemann's Avatar
Default 1996 xjs rear window won’t go down.
Originally Posted by Vee
Hoodun, are you sure its a relay and not a problem with the bearings in the window motor? When mine go bad, I tap the housing and it works again. A bad relay wouldn't respond that way, would it.
Vee,
how do you access the motor? I’ve read a few threads that mention a 24” screwdriver. That leads me to believe it can be done without tearing apart the interior panels. How do you tap the housing?
thanks,
George
Old Jan 27, 2024 | 12:12 PM
  #30
Vee's Avatar
Vee
If the top is down, it can be done. I’m not sure I can explain how to locate it by looking down into the cavity, but you should be able to find it if you know what you’re looking for.
Maybe if you go to JDHT and understand how it’s assembled, you’ll be able to spot the location?
This is only a temporary fix. It will get stuck again.
Old Jan 27, 2024 | 12:45 PM
  #31
gleudemann's Avatar
Thanks!
The Deacon
Mar 12, 2023 05:29 AM
Barry_Tucker
Jun 14, 2021 03:52 AM
Katzenfieber
Apr 23, 2020 12:37 PM
NCJagman
Oct 12, 2017 08:23 AM
malc4d
Jul 21, 2013 01:37 AM
