Marelli rotor thoughts?
Old Apr 11, 2020 | 04:05 PM
Doug's Avatar
Default Marelli rotor thoughts?
Came across this old Marelli rotor. Obviously it has suffered!
However......
I was pondering something......
The burning doesn't really seem that bad on this one; not burned clear through; I've seen worse.. And the center area, not seen in this pic, is OK. Is the rotor positively condemned? Can it somehow be salvaged? Reused?
Might first inclination was to simply toss it in the bin. And that's probably where it belongs. But since it is an original, true Marelli....maybe not?
Anyhow, I have no use for it. If someone here wants it, just give a shout and I'll drop it in the mail
Old Apr 11, 2020 | 11:10 PM
If it were mine, and being an original, I would try some repairs with JB Weld. Nothing to lose really.
I repaired a Lucas one I knackered, way back, and its still in the PreHE.
Old Apr 11, 2020 | 11:22 PM
Doug's Avatar
I was thinking about JB Weld myself. It's "The Mechanic's Best Friend", after all
Old Apr 11, 2020 | 11:25 PM
VancouverXJ6's Avatar
I'd like it for the purpose of building a 3D printed (quality) replica. You can even have it back when I'm done.
Old Apr 11, 2020 | 11:55 PM
Doug's Avatar
PM me mailing info and I'll drop it off in the mail
Old Apr 12, 2020 | 03:51 AM
Brake buster's Avatar
electricity is lazy , a bit like me as i am an electrician ,
it will always find the path of least resistance, this demonstrates how the spark will find a path to ground if its intended path is obstructed in some way , this can be as spark plugs and or poorly HT leads by way of high resistance (more than designed ),
a lot of observers will blame the rotor for failing, i say its the other parts of the ignition system making the rotor contacts seek another path to ground causing carbon tracking on the rotor arm , then once established the carbon track can be more attractive to the spark than the HT lead and spark plug ,
this goes for any make or brand of car....
a good idea to always keep genuine Marelli components, even if just for reference ,
very generous to post out to another member
stay safe
BB
Old Apr 12, 2020 | 08:07 AM
Asdrewq's Avatar
Out of interest what's wrong with the non-genuine Marelli cap/rotor's that are available?
Old Apr 12, 2020 | 08:42 AM
Doug's Avatar
There's nothing "wrong" with them. They fit and do the job. Personally, I've not heard of any actual problems coming as a result of using them.
But the true Marelli parts are much higher quality
anyoldiron
Oct 7, 2019 12:46 PM
Motard
May 4, 2019 11:56 AM
bburton
Mar 14, 2016 08:52 PM
Safari
Sep 27, 2015 03:07 PM
bullittandy
Mar 24, 2015 04:12 AM
