master cylinder specifics
Old Jul 25, 2022 | 03:21 PM
J_C_R's Avatar
Default master cylinder specifics
Changed to name from another post since I'm now concentrating on the master cylinder.
My master cylinder is a Girling. Girling says that the bore size is embossed on the cylinder. Despite my best efforts to clean it while its still in the car I can't make out the bore size. Since I can't find a master cylinder from Girling (or anyone else) I'll try rebuilding the one I have.
I can find the rebuild kits, but of course each kit is for a specific bore size. Does anyone happen to know if all V-12 (5.3L) XJ-S's were fitted with a particular bore size, and if so what this size is?
If push comes to shove I'll remove the cylinder and measure the bore, but that makes the car undrivable until the rebuild kit arrives. I'd like to keep down time to a minimum, so if I knew that 1987 XJ-S's all had the same bore size it would be helpful.
Thanks to all,
John
1987 XJ-S V12
Old Jul 25, 2022 | 04:08 PM
ptjs1's Avatar
John,
If you just put the part number of your master cylinder into google, everyone seems to indicate it's a 23.8mm diameter bore.
PAul
Old Jul 25, 2022 | 05:00 PM
J_C_R's Avatar
Problem is, 23.8 mm works out to 15/16th of an inch. Not a diameter Girling shows a kit available for.
My choices are 5/8", 0.70", 3/4" bore and 7/8" bore. The closest of these, 7/8ths, is 1.6 mm less in diameter than 23.8mm.
I wonder if the cupped washers are supposed to make up the difference?
Thanks,
John
Old Jul 25, 2022 | 05:25 PM
ptjs1's Avatar
John
Maybe easier to just buy a new cylinder? Options on ebay and ither direct sites.
Paul
Old Jul 26, 2022 | 01:12 AM
Greg in France's Avatar
Manners sell rebuild kits for the XJS of the correct size. All non-ABS HE cars had the same size of M/C.
Old Jul 26, 2022 | 09:01 AM
J_C_R's Avatar
Hi Greg,
Do you know what bore size?
I'd buy a master cylinder if I could find one. Lot's on e-bay, if you have a Vandan Plas, XJ12 or XJ6, but none that I can find for the XJS.
Thanks!
John
Old Jul 26, 2022 | 09:03 AM
Originally Posted by J_C_R
Hi Greg,
Thanks!
John
Sorry, no idea; I just know kits from Manners will fit. Also, if you are really stuck there are places in England that refurb M/Cs and as part of the process line the bore with stainless tube.
Old Jul 26, 2022 | 03:19 PM
ptjs1's Avatar
John,
Not sure where you've tried, but on the face of it, there doesn't seem to be a problem. Just 30 secs on Google turned up the following from the usual Jaguar US independents::
https://www.jagbits.com/product/CAC1583-X.html
https://www.ebay.com/itm/37417551233...512338&vxp=mtr
https://www.terrysjag.com/product/PMK179.html
Paul
Old Jul 26, 2022 | 03:20 PM
J_C_R's Avatar
Thanks Greg.
I just pulled it and am going to send it to a refurbuisher in Virginia, an outfit called White Post Restorations. Talked to them today, they seem competent. They say they can turn it around in 1.5 - 2 weeks for $200 and change. They also sleeve it with stainless steel.
As an aside they said they can't work on Teva (sp?) units due to special tools required and lack of parts.
We shall see.
Thanks to all for the input,
John
1987 XJ-S V12
Old Jul 26, 2022 | 05:32 PM
sanchez's Avatar
I purchased a brand new Master Cylinder from Paul's Jaguar in Ft Lauderdale and received it yesterday. I have already installed it and bled my brakes. So all is good.
None of the vendors listed above with the exception of the ebay ad (Paul's Jaguar) has this item in stock.
Welshent has a refurbished one but require a $200.00 core charge.
Old Jul 27, 2022 | 01:25 AM
Thanks Greg.
We shall see.
John
1987 XJ-S V12
Great solution. I think that more and more we will have to take this type of fix to such parts. Only 5 years ago all these parts were plentiful.
Old Jul 27, 2022 | 08:44 AM
J_C_R's Avatar
I looked at all those a few days ago, they all showed out-of-stock.
Anyway, it's on its way to Virginia for a refurb.
Thanks,
John
Reverend Sam
Jun 25, 2021 01:53 AM
rande
Mar 25, 2021 12:52 PM
Aplanir
Jul 6, 2017 02:01 PM
Brandon Wright
Sep 1, 2016 04:38 AM
