New Fuel Pump - Now No Start..
Old Sep 13, 2014 | 01:24 PM
Broken_Spanners's Avatar
Default New Fuel Pump - Now No Start..
Ah yes, another of the 15,000 no start threads restarted..
Quick one this time, original pump was leaking badly, car never had starting issues prior to replacing pump. I bought the blue one that XK's sells, and replaced the filter at the same time.
All button up, no start. I cycled the key about five times prior to engaging the starter, but still no go. There doesn't appear to be pressure after the filter.
Question being, could I just have an air-lock and need the thing to sit a while, or do I need to open the sump and see if it ingested some junk?
I triple checked that I pulled all the packing covers off the pump and the filter, so that shouldn't be the issue.
Would jumping the pump help to let it clear it through rather waiting on the ECU to call for the pump at start / prime the system better?
Thanks.
Jeff
Old Sep 13, 2014 | 01:29 PM
Daim's Avatar
Change the wires on the pump. + to - and - to +.
Old Sep 13, 2014 | 01:38 PM
XJSFan's Avatar
I may be spacing out, but do you have to push the fuel pump reset button under the passenger side dash?
Old Sep 13, 2014 | 02:18 PM
sidescrollin's Avatar
I have changed my fuel pump, filter, and removed my gas tank among other things. Never had to prime anything, never had to reset the fuel cutoff switch, nada.
question #1, is there power at the fuel pump and is it properly wired?
question#2 are you SURE the hoses are correctly routed?
Old Sep 13, 2014 | 03:59 PM
Daim nailed it! The bloody pump was mismarked!!!!! I felt suction on the output, switched around the terminals and fired right up!
Thanks guys..
Jeff
Old Sep 13, 2014 | 04:30 PM
Daim's Avatar
Thanks guys..
Jeff
Happened as I did my pump too
The car is wired uncommonly... Or better typical for British cars
Old Sep 13, 2014 | 10:40 PM
DRINKS ON JEFF.
Ya simply got to luv a plan that falls into place.
Old Sep 14, 2014 | 10:15 AM
XJSFan's Avatar
Fantastic!!!
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
