oil leak behind drivers seat xjs conv 1996
Old Apr 17, 2015 | 10:49 AM
jag_xjs_1996's Avatar
Default oil leak behind drivers seat xjs conv 1996
I was wondering if anyone could help me
I have a leak from the bottom of the car
near or behind the driver door, USA, so left hand side around the wheel well
I have looked under as much as I can and it seem to come from a joint where the suspensions are
I will attached 2 pic
I am assuming some bushing need replacing
and assuming this is some brake fluid?
please help
ab
Attached Thumbnails oil leak behind drivers seat xjs conv 1996-photo.1jpg.jpg   oil leak behind drivers seat xjs conv 1996-photo.jpg
Old Apr 17, 2015 | 10:52 AM
the color of the fluid is clear, so I am guessing it is brake fluid
Old Apr 17, 2015 | 01:14 PM
sidescrollin's Avatar
You sure it isn't fluid from the top?
If it was brake fluid all of the paint and undercoating would have peeled off.
Old Apr 17, 2015 | 01:53 PM
ptjs1's Avatar
ab,
Be careful to check this urgently as those are your fuel flow and return pipes that are running there. Is it petrol that's leaking?
By the way, it's great to see such a good condition underside for the radius arm mount! I'm guessing this is a very low-mileage car!
Paul
Old Apr 17, 2015 | 02:44 PM
xjsv12's Avatar
Check conv hood lift fluid
Old Apr 17, 2015 | 03:02 PM
I think you are absolutely right
the conv auto top has not been working
you are the man
do you have any idea, what I do next
i think you are right, you are great, someone else replied the same
do you know what i do next
Old Apr 17, 2015 | 03:20 PM
I am completely unfamiliar with the convertible system in the XJS. You need to locate the hoses,pump,etc and inspect them until you find what is leaking.
I can only guess that it is behind the rear panel, I don't think it is in the trunk because the convertible trunks I have seen have the same panels. Hopefully someone can chime in that knows more about the convertibles.
You could always remove the panels behind the seats and the panels in the trunk to look around for access. That's what I would end up doing.
Old Apr 17, 2015 | 04:02 PM
ptjs1's Avatar
Yes, the convertible pump is in the boot above the battery.
It's not impossible, but i would still think it unlikely that hydraulic hood fluid would get from the left hand ram (the pump is on the right) to the left radius arm which is under the body. I guess it could perhaps work its way down and out? It's not common for the rams to leak.
If you haven't got Jaguar's official parts and service manual, I'd very strongly suggest that you buy it if you're going to run an XJS.
Good luck
Paul
Old Apr 17, 2015 | 04:21 PM
paul
thank you so much for that advice, seems i will have to follow it
would like to ask another favour, i just found this site were they list manual, can you advise on which i should get, i own a 1996 4.0 convertible usa model jag
XJS, 1996 Jaguar XJS Manuals
i am thinking about purchasing
1991-1996 Jaguar XJS 4.0L Parts Catalog & Service Manual DVD that product, is that the best option?
Old Apr 18, 2015 | 05:14 AM
ptjs1's Avatar
jag_xjs_1996,
Jaguar produced a number of DVDs covering the differing XJS variations. However, these are not fully compatible with Mac operating systems so be aware. If you buy one of these, the one you want for your car is Jaguar part number JHM1143. This is the one shown in that link you posted but seems very, very expensive at $140! They are only about £25 from Jaguar's Heritage division although I THINK that JHM 1143 is out of stock at present. See here and try contacting them by phone and ask:
Jaguar Heritage. Technical Publication DVDs
Recently, they've released a new DVD which covers all variants of XJS and has much additional material. This is more expensive but still only £50. See here:
Jaguar Heritage. DVD's
Hope that helps
Paul
Torrid
Feb 15, 2020 08:03 AM
DrScientist
Dec 9, 2015 07:36 PM
Don Elliott
Sep 2, 2015 09:38 AM
peterg19
Aug 28, 2015 08:42 AM
