oil plug size
Old Jul 14, 2014 | 10:48 PM
dtony's Avatar
Default oil plug size
Does anyone know the size if the oil plug for a 90 XJS ?
Thanks,
Tony
Old Jul 14, 2014 | 11:16 PM
Eaa's Avatar
Eaa
V-12 engine? My 91 was listed as 16mm in catalogs, which seemed about right by sight but I didn't measure it. Are you looking for a replacement plug?
Old Jul 15, 2014 | 07:31 AM
dtony's Avatar
No, just finding the correct wrench for it. I have a 19MM and it is too small.
Tony
Old Jul 15, 2014 | 08:59 AM
Mine is 22mm, or 7/8".
Old Jul 15, 2014 | 09:01 AM
XJSFan's Avatar
What size is the drain plug washer for the 90 XJS?
Old Jul 16, 2014 | 12:55 AM
Eaa's Avatar
Eaa
Tony
Sorry Tony, I thought you were asking about the size of the threaded plug itself, not the hex.
From memory, I think mine is also 7/8".
Old Jul 16, 2014 | 01:07 AM
Eaa's Avatar
Eaa
My drain plug, I believe, is 16mm diameter for the threaded part, so the washer slightly larger id than that. I found quite a lot of info and choices on the internet regarding that washer.
Old Jul 16, 2014 | 07:25 PM
dtony's Avatar
Finally got it.
The hex size for my 90 XJS is 22MM. I want you all to know, however that plug was really put in there. It took a lot of effort and a few bangs of a hammer to break it free.
Thanks for your help!!!
Tony
Old Sep 14, 2014 | 06:28 PM
GSHastings's Avatar
In case others have a similar problem, my drain plug requires a 30mm socket!!!
'93 XJS 4.0L VIN 186126
Old Sep 14, 2014 | 10:48 PM
dsetter's Avatar
Just had mine out today for a new batch of oil. It was a7/8" wrench and a 16mm washer.
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
kelliott
May 31, 2022 05:26 PM
Scarecrow
Mar 28, 2016 03:17 AM
AL NZ
Sep 4, 2015 08:39 PM
