Oil pressure
Old Jan 5, 2018 | 12:06 PM
gerben's Avatar
Default Oil pressure
xjs 3.6 liter 1985.
oil pressure at 5 with ignitin on,engine off.
pressure 7 engine idle.
changed the pressure swith,no help.
what could be the problem ?
Old Jan 5, 2018 | 01:19 PM
Welcome to the forum gerben,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Jan 5, 2018 | 02:36 PM
warrjon's Avatar
Originally Posted by gerben
xjs 3.6 liter 1985.
A bad connection on the oil pressure sender or instrument cluster plug.
If you disconnect the oil pressure sender the gauge will go full scale.
Old Jan 5, 2018 | 03:51 PM
Mark SF's Avatar
Had the engine been running recently? A good one won't leak down oil pressure right away.
Old Jan 6, 2018 | 03:08 PM
gerben's Avatar
engine is running regulary.
does not leak down oil presure.
the gauge reads 5 before engine runs. thenn climbes to 7 on idle..
Old Jan 6, 2018 | 04:17 PM
Steve M's Avatar
Does the oil pressure warning light come on at any time?
Old Jan 7, 2018 | 01:58 AM
Greg in France's Avatar
This is an electrical gremlin. Nothing to do with the actual engine.
Old Jan 7, 2018 | 06:04 AM
gerben's Avatar
no light coming on.
oil pressure is fine.. it is the electrics that causes problems.
Old Jan 7, 2018 | 06:08 AM
gerben's Avatar
checking the instrument cluster is a p@&#+ in the b@#$.
the engineer who invented the system with the printed circuit under a layer of plastic,realy did NOT do us a favor.
Peter Yegen
E type ( XK-E )
Nov 8, 2016 11:07 AM
itchyback
Nov 1, 2016 10:40 PM
Daim
Oct 9, 2016 03:08 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
catinkansas
Aug 7, 2007 08:20 PM
