Plug ID help please . . .
Old Jun 26, 2021 | 10:50 AM
petemohr's Avatar
Default Plug ID help please . . .
1996 XJS Conv.
The white plug in the center is for the antenna.
What is the Black plug (circled in red) for?
What is the Plug on the left with the jumper for?
Also, if someone has a picture of the antenna mounting bracket that would help.
Thanks - pete
Old Jun 26, 2021 | 11:23 AM
equiprx's Avatar
Pretty sure that black plug is for the antennae delay relay.
Old Jun 26, 2021 | 11:40 AM
Spikepaga's Avatar
i think so too. Unless your car has a spoiler, you would not have it
Old Jun 27, 2021 | 06:26 AM
petemohr's Avatar
Thanks to equiprx and spikeaga.
No hints as to the plug with the jumper?
Old Jun 27, 2021 | 06:32 AM
ptjs1's Avatar
pete,
I'll be with my 95 AJ16 convertible on Tuesday. I'll take a pic of my setup
Paul
Old Jun 27, 2021 | 08:23 AM
petemohr's Avatar
Originally Posted by ptjs1
pete,
Paul
Thanks - I really appreciate that!
Old Jun 29, 2021 | 09:58 PM
OldCoastie's Avatar
On my 94 2+2 I have a plug resembling the white one that goes to the diagnostics plug. Why there is a jumper is a mystery.
Old Jun 30, 2021 | 04:49 AM
equiprx's Avatar
That plug might be for the tow hitch option.
Old Jul 3, 2021 | 06:03 AM
ptjs1's Avatar
Pete,
Some possible answers - Part 1
I went down to the car last night and removed the rear trim to get some pics.
At first. I couldn't see any of the plugs to which you referred, so I started taking things apart. Eventually I found the plug which had a jumper. I'm not sure what it is but mine does have a label which seems to say DAC 10608. I've googled that but can't seem to find an answer as yet.
I couldn't see the black plug, so eventually I decided to remove the fuse box to see if it was behind there.
With a lot of fiddling, I then found what I think is the black plug. On mine, it's taped up with red tape, as you can just see at the top of one of the pics. There seem to be wires coming out of the top of the taped bit, but I will have to remove the top bracing strut on the upper inner wing edge to be able to access where it seems to go. I'll try and do this next week.
I've just realised you asked about the aerial mounting bracket. I'm due to go back to the car today, so will see if I can photo that.
Hope that helps a bit.
Paul
Old Jul 3, 2021 | 06:39 AM
petemohr's Avatar
Thanks for taking the time to do this.
You did solve one thing. I was thinking that the band around the antenna was another mounting place. from your pictures, I can see it's a ground for the shield in the antenna cable.
Thanks again.
Old Jul 3, 2021 | 09:02 AM
ptjs1's Avatar
Pete,
Does this help you at all on the aerial bracket?
If not, tell me which views you need.
Paul
Old Jul 3, 2021 | 09:25 AM
petemohr's Avatar
That's perfect!
How is it fastened to the floor?
asjdhsajhdfj
Jun 11, 2021 12:48 PM
Barry_Tucker
May 3, 2019 08:16 PM
daro31
Jan 1, 2015 11:42 AM
grogers1
Jun 18, 2014 02:47 PM
jagxkrtoofast
Nov 17, 2009 02:45 AM
