Possible project
Old Aug 27, 2018 | 02:08 PM
Jammymutt's Avatar
Default Possible project
Hi guys, ive just joined today and im looking for advice help , a slap in the face, the truth im scared, I have just spent a lot of time restoring a VW Scirocco and then a Polo the little breadvan type.
I went to see someone today looking to buy a Morris Minor but i seen these two beauties and im contemplating getting one whilst my son has the other the red one.
What am i likely to face?
Old Aug 27, 2018 | 10:47 PM
Doug's Avatar
If you wanted a project, you've found one !
Rust repair-paint-chrome-leather can run into serious money but you probably already know that!
Most mechanical stuff on these cars is well within the realm of a decent DIYer. Most mechanical parts are readily available and not hugely expensive. Great internet support, too!
It's a fair bet that every sub-system will need attention: brakes, fuel system, suspension, HVAC, etc. But, if you're planning an actual restoration you'll be overhauling each system anyway
The Jag 6-cylinder engines are rugged old birds. There's a decent chance that the engine itself won't need any any significant work.
XJSs are fabulous cars once everything is sorted out.
Old Aug 28, 2018 | 11:19 AM
Jammymutt's Avatar
Thank you Doug the only thing I can’t s is weld but I think I’m going to buy a mug welder and learn about it , yeh I’ve been told by so many people these engines are amazingly good sadly it’s been sat outside for 10 years so rust will be our biggest issue I think .
Im going in Wednesday to attempt to start it as it won’t be worth it if it’s a non runner but it’ll be a challenge and hopefully fun on the way for myself and my son .
we've done two cars already but this is a far bigger project off us .
there will be blood sweet tears and arguments I’m sure but if it’s in the road within a year and we get a drive in it I’ll be extremely happy then we can start in the red one of his
Old Aug 28, 2018 | 11:36 AM
bladerunner919's Avatar
Don't be amazed if it doesn't start, but don't necessarily let that put you off. Fuel pumps die when not used, but are a simple fix on a car of that age, or a connector could be disconnected if someone's been fiddling under the bonnet.
Also, I'm in for pics of the Blue Rover P6 and intrigued to see more of what looks like a bright yellow Granada with something attached to the roof!
Old Aug 28, 2018 | 01:05 PM
Jammymutt's Avatar
Im going back tomorrow night there are at least 4 or 5 Rover P6s with V8 engines sitting there all for sale under £1000 each 2 Morris Minor split screens , a Mk1 3ltr Capri I tihnk the granad has something to do with a gumball rally or something like that.
Theres a Wolseley andother Mk1 Capri in a bad state so many nice old cars and all for sale !!!
Old Aug 28, 2018 | 01:34 PM
JayJagJay's Avatar
Don't write it off JUST because it doesn't start after sitting for as long... Usually it's not a complicated fix to get it running... And,,, the folks here will walk you thru most anything... Rust does matter!
Old Aug 29, 2018 | 01:13 AM
Greg in France's Avatar
Be very careful, say I. To get those cars back to decent condition, inside and out, will be a great deal of work and a very great deal of cash - even if the cash part is limited to buying the required parts. Welding ability is essential, and welding bodywork is not easy - I would go on a bodywork welding course before buying.
Looking at the pics, I can see loads of parts that look in poor condition, and for sure every single rubber bush and mount will need renewing, and a great deal will need spending on the interior parts, if they can be found at reasonable prices.
From a budgetary point of view, I would try to find a running car, or a car that has no serious rust at all that someone has given up on or just got fed up with. Undoubtedly a running car you can "rolling restore" will be cheaper as a project that these two; and undoubtedly a rust free car will be a far better basis for a full restoration. 3.6 engine cars in the UK, with MoTs are not particularly sought after or expensive, either.
Old Aug 29, 2018 | 01:50 AM
brinny's Avatar
j
greg has it summed up. I have done the mechanicals on my car and things are not cheap. Still a long way to go as well. I did all my own welding and that took some time. If you have restored a car before you will know how much effort is involved beside cash. Like I said Greg has it in a nutshell.
The Coupe
Jan 6, 2021 10:54 AM
1badjag
XJ40 ( XJ81 )
Feb 13, 2010 04:15 PM
tkpagel
Jan 21, 2008 02:27 AM
Dec 29, 2006 03:05 AM
